F4 smoking - MVAgusta.net
post #1 of 5 (permalink) Old 11-13-2009, 10:39 PM Thread Starter
borg4life's Avatar
F4 smoking
noticed smoke coming from front end today. took off fairing and watched oil drip from where one of the pipes connects to the engine block. what's the ailement and what's needed to fix it. thanks
borg4life is offline
post #2 of 5 (permalink) Old 11-13-2009, 11:25 PM
oil leak
which pipe?
you should be able to see if its the valve cover seal/or 1 of the 8 mounting nuts or the line above #2 cylinder
if its the valve cover or a nut you'll have to reseal it
if its the line, see if the clamp bolt is tight/check the condition of the o-ring
post #3 of 5 (permalink) Old 11-14-2009, 12:59 AM Thread Starter
borg4life's Avatar
which pipe?
if you are sitting on the bike, it would be the second pipe on the left (and if you are sitting on the bike, you would also be looking at the side of the pipe that is dripping)
post #4 of 5 (permalink) Old 11-14-2009, 01:36 AM
leak
borg4life;
call me 310-540-4823
post #5 of 5 (permalink) Old 11-14-2009, 02:12 AM Thread Starter
borg4life's Avatar
borg4life;
thanks for the help.
