312R Ride height measurement needed - MVAgusta.net
post #1 of 6 (permalink) Old 08-14-2009, 08:58 AM Thread Starter
Does anyone have an as delivered 312R they could do a ride height measurement on? I have a customer who'd like to go back to factory height, but I really don't see the point in paying $680 odd for the factory tool and somewhat understandably the importer won't lend one to me.
Preferably on a rear stand measuring from the axle up to the lowest point of the bottom of the air vent on the seat base. The factory spec is fully extended, but I should be able to infer it from the "sag without rider" measurement.
Thanks.
brad black is offline
post #2 of 6 (permalink) Old 08-15-2009, 02:12 AM
ride height tool
brad black;
2 days ago ProItalia quoted me $195 for the tool, I said no thanks!
any one have the dimensions of the tool? pin diameters and the angle/distance to the measuring spot that is marked on the long arm?
i'll just make one
post #3 of 6 (permalink) Old 08-17-2009, 02:46 AM
Vector's Avatar
Hi Brad,
I have a new 312R only 500 kms on it with no suspension or other adjustments done so far.
I measured the bike whilst on the rear stand. I measured on the chain side of the bike between the very top of the stand and the very bottom of the stamping on the side of the exhaust. The stamping I measured to was the E3 box nex to the part no.
This measurement was exactly 500 mm between the two points.
Let me know if this works for you. I could not find any other reference points that would be easy to describe.
Vector is offline
post #4 of 6 (permalink) Old 08-17-2009, 05:07 AM
flying kiwi's Avatar
No Prob
Have 312r with no adjustment made to hieght yet ,Although I intend to lower both front and back by same to keep head angle same but lower standover. will check tomorrow and get back with what I find, also you may need front measure from clamps to top of fork as this may have been changed
flying kiwi is offline
post #5 of 6 (permalink) Old 08-17-2009, 05:39 AM
Vector's Avatar
Originally Posted by flying kiwi View Post
No Prob
I like your thinking kiwi,
I have just measured from the top of the triple clamp to the top of the fork (not adjuster) and have a distance of 7 mm. This was measured closest to the centre of bike (shortest height).
Vector is offline
post #6 of 6 (permalink) Old 08-18-2009, 12:16 AM Thread Starter
Thanks Vector. This one has RG3 on it, so no E3 marking. Typical. PS have a new one on the floor so Chris the owner of this one is going in to take a measurement off it.
If only they had an easy official way to set it. Well, I guess the $680 tool is very easy.
