Australia and Engine Ice - Page 2 - MVAgusta.net
post #11 of 19 (permalink) Old 09-17-2009, 08:17 AM
minime's Avatar
Engine Ice boiling point is 124 degree celsius or 256 fahrenheit. Wow you were quoted 2 hours to install the impeller!!!
minime is offline
post #12 of 19 (permalink) Old 09-17-2009, 09:18 AM
AndyF4's Avatar
Yep. That was about the point that I lost interest in the conversation with them.
MV Agusta 05 F4 1000
BMW 09 K1300S
Ducati 00 748R
AndyF4 is offline
post #13 of 19 (permalink) Old 09-17-2009, 06:42 PM
jose's Avatar
I'm about to get a 312R and had the high output waterpump upgrade quoted here in Sydney. $440 including one hour labour.
The parts were $277 for the cover, $46 for the impeller and $7 for the O ring.
The parts are not in stock but can be ordered.
As for the Engine Ice shortage the dealer (Motorino Darlinghurst or Homebush) said they were expecting new stock by the end of October.
jose is offline
post #14 of 19 (permalink) Old 09-17-2009, 07:41 PM
Dova80's Avatar
Guys there is something a bit better than engine ice IMHO its called NPG from Evans Cooling systems.
http://www.evanscooling.com/main27.htm
http://www.evanscooling.com/html/npgPls.htm
Boiling point of over 350 F and has no water in it.
My cousin uses this in his race cars, and told me to look into it, and it does work wonders.
Dova80 is offline
post #15 of 19 (permalink) Old 09-17-2009, 10:05 PM
Stiv's Avatar
Originally Posted by Ian Baldwin View Post
Stiv,
I remember seeing the third fan mod on your bike. I'm starting to lean towards the third fan idea as I only have a problem when I'm sitting at a red light and I don't see the new water pump and impeller improving this in 30 to 40'C days.
Can you send me the details of what you did again or lead me to your thread on the site where you had the instructions and photos please?
I found a guy at work who builds hot rods who also happens to be an auto electrician......I'm not confident doing something like this on my baby and I'm not that mechanically minded. Yes I know, 'shame on me'.
Also, would it be of any use putting the bike on a dyno tuner or putting a power commander in it?
I hope you can help,
Ian
Hey Ian
If you have an older model f4 you may find the impellor mod and muzzy fans will be enough to hold the heat at bay.
In my case (1078), those mods helped but didn't stop the temp from continuing to climb on hot days stuck at lights. That's why i put the 3rd fan in. It's pretty clear that the more horses, the more heat.
Different coolants may help the bike run a few degrees cooler at speed but they are not going to have a dramatic effect on heat soak or a system under stress when stationary.
Every little bit helps though. Before..... my temperature range was 87-117c+. My bike now runs in a narrow temperature band of 87-102c under all conditions.
This happens because of the mods i have done not because of the coolant i use. Motul coolant works fine.
Stiv
Stiv is offline
post #16 of 19 (permalink) Old 09-18-2009, 12:34 AM
MRT
MRT's Avatar
I too have been told by a dealer that engine ice isn't that good, but all the people on this forum can't be wrong. The workshop that are doing my bike now said they have seen good things with a nulon product, so I told em to put it in and see how it goes. I also wanted the H.O. water pump fitted while the coolant is out but there was nil stock locally. See how we go, I may fit it later.
MRT is offline
post #17 of 19 (permalink) Old 09-18-2009, 01:51 AM
AndyF4's Avatar
Hmm we are both in Queensland. Whats a bet it was the same dealer. If you decide to get the impeller let me know. The instalation if really quite easy and I definitely wouldn't pay someone to do it.
BMW 09 K1300S
Ducati 00 748R
AndyF4 is offline
post #18 of 19 (permalink) Old 09-18-2009, 05:19 AM
MRT
MRT's Avatar
I am going to wait and see how my bike goes when i get it back and if required i will fit the new water pump. It looks simple, i was just hoping to get it fitted while they had the coolant out so i didn't have to drop the coolant. Is your dealer one of the Brissy shops or a little further north?
MRT is offline
post #19 of 19 (permalink) Old 09-18-2009, 05:37 AM
AndyF4's Avatar
LOL yep a little further north.
BMW 09 K1300S
Ducati 00 748R
AndyF4 is offline
