my f4 over Heat - MVAgusta.net
post #1 of 17 (permalink) Old 07-27-2009, 09:04 AM Thread Starter
fr0gman's Avatar
Unhappy my f4 over Heat
Hello guys!
Why is my new F4 1+1 over heats? it gets to 230-236 sometimes?
is this normal? what do i need to do?
fr0gman is offline
post #2 of 17 (permalink) Old 07-27-2009, 09:25 AM
Timster's Avatar
http://www.mvagusta.net/forum/showthread.php?t=24942
__
MV F4 1000 S Red/Silver
HUSABERG FS 570
Timster is offline
post #3 of 17 (permalink) Old 07-27-2009, 09:43 AM
Stiv's Avatar
Stiv is offline
post #4 of 17 (permalink) Old 07-28-2009, 04:25 PM
If you are still breaking in your f4 it will tend to get hot. For some reason as the motor breaks in it will run cooler. Mine has cooled off a good 10 degrees or more.
white312inclt is offline
post #5 of 17 (permalink) Old 07-28-2009, 04:47 PM
Spartukus's Avatar
Send a message via AIM to Spartukus Send a message via Skype™ to Spartukus
Don't let it get above 238 degrees or your bike will shut down and your battery will be drained!
Don't make excuses, Make it happen
05 F4
07 SENNA (261/300)
13 F3
04 Ducati 749s (Track Project)
06 CBR600RR (Track Project II)
08 Aprilia RSV (Rest In Pieces)
Spartukus is offline
post #6 of 17 (permalink) Old 07-28-2009, 05:41 PM
RikiRix's Avatar
When the fuse was burned i got 140 C (284 F). The engine didn't stop but the coolant was boiling and finally spitted from radiator; it's when i finally noticed temperature read and immediatelly turned off engine with, thanks God, no damages.
Since then i always keep an eye on temperature.
Till 114/120 C (248 F) no problems normally. With F4 312 even a bit more.
SUZUKI RG250 - YAMAHA RD 350 - YAMAHA RD 500 - SUZUKI RG 500 - SUZUKI GSXR 1100 - KAWASAKI ZXR 750 - DUCATI 851S - DUCATI 888 SP4 - MV AGUSTA F4 1000S
RikiRix is offline
post #7 of 17 (permalink) Old 07-28-2009, 06:10 PM
Step 1) purge the system of any air.
Step 2) Fill the coolant bottle to the proper level.
Step 3) Make sure the plastic cap is holding pressure.
If none of the above solve your problem, start looking at the fixes posted in numerous threads.
post #8 of 17 (permalink) Old 07-29-2009, 03:08 PM
Yeloboi's Avatar
Buy the new impeller works wonders. I haven't had any problems since!!!!
Yeloboi is offline
post #9 of 17 (permalink) Old 07-29-2009, 04:10 PM
I can confirm the new impeller works a treat ( we fitted one recently ) I have also heard that a product called Engine Ice works well and is a coolant replacement but not tested it yet.
londonsuperbikes is offline
post #10 of 17 (permalink) Old 07-29-2009, 05:02 PM
Timster's Avatar
i have both, the new oem impeller in combination with engine ice. Works a treat!
__
HUSABERG FS 570
Timster is offline
