Fans not working - MVAgusta.net
post #1 of 12 (permalink) Old 07-26-2009, 03:59 AM Thread Starter
Toby SPR's Avatar
Unhappy Fans not working
Took the SPR out for a lovely blast yesterday but my pleasure was rudely halted by a rising temperature gauge. The bike normally strays up to 92 but (was hot granted went above 100). I noticed the fans were not working before It spat coolant out of the overflow pipe (about a half a cup full). luckily I was close to home and took off the very hot fairings......my questions are "what is normal temp for the F4's" and to save me tracing back every wire...is there an easy check or fix....i was thinking of putting a power feed direct to fans to check working (naturally) but after that where should i look. Appreciate there are loads of forums on this subject and have read most of them.....really appreciate anyones thoughts as keen to get back out there...cheers
Toby SPR is offline
post #2 of 12 (permalink) Old 07-26-2009, 04:29 AM
Banned
if I remember right its around 102/104 degrees that the fan kicks in,
if your fans are not working check the diode as this was the fault with my EV03, which was discovered after many hours/days back at the dealer
check back the threads on this, there are a few
use the search tool above.
F41NXS is offline
post #3 of 12 (permalink) Old 07-26-2009, 04:36 AM
RikiRix's Avatar
Happened to me too. It was the fuse.
SUZUKI RG250 - YAMAHA RD 350 - YAMAHA RD 500 - SUZUKI RG 500 - SUZUKI GSXR 1100 - KAWASAKI ZXR 750 - DUCATI 851S - DUCATI 888 SP4 - MV AGUSTA F4 1000S
RikiRix is offline
post #4 of 12 (permalink) Old 07-26-2009, 06:40 AM
adamv1000's Avatar
+1
adamv1000 is offline
post #5 of 12 (permalink) Old 07-26-2009, 07:24 AM
Banned
It happen to my friend, it was the fan blades, melted.
stephen wood is offline
post #6 of 12 (permalink) Old 07-26-2009, 07:46 AM
RikiRix's Avatar
Maybe your friend forgot to check the fan cool fuse?
RikiRix is offline
post #7 of 12 (permalink) Old 07-26-2009, 05:11 PM
ducracer18's Avatar
Check the relay on the right side of the frame behind fairing, near the top of the rad. Mine melted when too close to headers.
ducracer18 is offline
post #8 of 12 (permalink) Old 07-26-2009, 05:17 PM
Harvey's Avatar
This happened to me, it was the little black relay behind the fairing just in front of where your right knee might be.
Not expensive, unplug it and take it to any electrical component place, should be able to sort you out.
Mine is a four-spade connection, the only marking I can see is '13/03/03V'. I've no idea what this means.
Harvey is offline
post #9 of 12 (permalink) Old 07-27-2009, 03:06 PM Thread Starter
Toby SPR's Avatar
Ok gents....it was the diode.....good work and many expensive man hours saved.......god bless you all....
Toby SPR is offline
post #10 of 12 (permalink) Old 07-27-2009, 03:35 PM
Banned
yep cost me a fortune on man hours and roughly £2.50 for the diode
still, every day is a school day
F41NXS is offline
