R312 Rear Tire - MVAgusta.net
post #1 of 4 (permalink) Old 07-21-2009, 06:16 PM Thread Starter
R312 Rear Tire
Has anyone used a 190/50 rear tire instead of the stock 190/55?
If so, what are the pros and cons?
Thanks,
848SD
848SD
-- '08 312R
-- '08 848
-- '07 VFR800
-- '93 CBR900RR
-- '74 RD350
848SD is offline
post #2 of 4 (permalink) Old 07-21-2009, 07:19 PM
The_castle's Avatar
I've used both on a 312R. I would say go for the 190/50/17.
Just my opinion but the bike just seems to turn in a little better so +1 for the 50.
The_castle is online now
post #3 of 4 (permalink) Old 07-22-2009, 12:50 AM
RT1
RT1's Avatar
doesn't make much difference at all, you just get better tyre options going with 190/50/17
RT1 is offline
post #4 of 4 (permalink) Old 07-22-2009, 05:20 AM
minime's Avatar
I when from 190x50 to 190x55 rear and I prefer the 190 x 55.
Pros of 190 x 55
- bike turns in quicker due to higher rear height.
- additional more grip at full lean, so I can be earlier on the throttle.
- higher top speed
- bike will have even more lean angle
cons of 190 x 55
- a little more expensive to purchase
- heavier tyre
- speedo will be slightly out
- similar feeling of removing one tooth at the rear sprocket
minime is offline
