Not starting... - MVAgusta.net
post #1 of 8 (permalink) Old 07-20-2009, 05:30 AM Thread Starter
RT1
RT1's Avatar
Not starting...
just got back from japan and my bike wont start?? it clicks like its got a flat battery but it is fully charged.....thinking it might be a problem with the pc3........any other common reasons?
RT1 is offline
post #2 of 8 (permalink) Old 07-20-2009, 06:47 AM
Does the pump prime? Does the tach do its little dance? Do the lights on the PC3 come on?
If the battery is charged and the bike has been sitting a while, I would check the connections at the battery and starter first. Any chance they are loose or corroded?
post #3 of 8 (permalink) Old 07-20-2009, 07:31 AM Thread Starter
RT1
RT1's Avatar
yeah it alln happens just doesn't turn ova, just clicks like a flat battery
RT1 is offline
post #4 of 8 (permalink) Old 07-20-2009, 09:18 AM
Banned
there may be power in the battery to do the prime and "tacho dance"
but not enough to kick the bike over,
ive had that often with battery; but if yours is fully charged as you say, it counts this out.
I also had problems with datatool alarm, which is best to be ripped out of the loom and thrown away
what length of time has the bike been sitting?
charge that battery one more time
F41NXS is offline
post #5 of 8 (permalink) Old 07-20-2009, 01:16 PM
Nicolino's Avatar
Batery conection ,make sure the cables are clean of rust and properly tighten. also starter cable .
Nicolino is offline
post #6 of 8 (permalink) Old 07-21-2009, 04:32 AM Thread Starter
RT1
RT1's Avatar
well i'm stumped, went to start it this morning and it fired right up, like nothing was wrong and i didn't touch it at all.......this bike is really confusing me, might be my alarm playing up........
RT1 is offline
post #7 of 8 (permalink) Old 07-21-2009, 04:43 AM
Banned
unless that alarm is really needed for insurance purposes, get rid of it
they are the pain of F4's nothing but trouble and battery drainers, remove it from the loom and throw away
F41NXS is offline
post #8 of 8 (permalink) Old 07-21-2009, 04:58 AM
minime's Avatar
If the battery is over 2-3 years old, I would change the battery first. I had the same problem, it was really hard to crank over when cold, ie outside temperature about 8deg. Once a new battery has been installed, she starts up first go!
minime is offline
