whats this hole for?? - MVAgusta.net
post #1 of 10 (permalink) Old 07-07-2009, 09:38 AM Thread Starter
RT1
RT1's Avatar
need help..... i am getting a coolent leak from the back of the waterpump housing and i think this hole could be the problem, just wondering what it is for and if it is ment to be sealed?
RT1 is offline
post #2 of 10 (permalink) Old 07-07-2009, 09:48 AM Thread Starter
RT1
RT1's Avatar
did a bit of research and found this
http://mvfaq.blogspot.com/2005/08/wa...p-leaking.html
this bike is starting to shit me
RT1 is offline
post #3 of 10 (permalink) Old 07-07-2009, 09:48 AM
number2's Avatar
I just disassembled my waterpump and based on the location of the hole I can't see why that would cause a leak. It's inside the waterpump. The only thing that would cause a leak at the water pump would be a bad gasket or a leaking hose/clamp. Unless, (bite my tongue and hope this isn't the problem) you have a crack in the engine case. Make sure it's not coming from the overflow hose. Mine did that once because of too much coolant.
number2 is online now
post #4 of 10 (permalink) Old 07-07-2009, 10:26 AM
I had the same issue replaced #19 8000A6708 and hasn't leaked since.
angrysea is offline
post #5 of 10 (permalink) Old 07-07-2009, 10:49 AM
ERIKF41000's Avatar
That hole might serve the same purpose as the hole on car water pumps. IF the seal for the water impeller shaft starts to fail it will seep through that hole and out of the engine to let you know that the seal is failing. But I am not 100% sure.
ERIKF41000 is offline
post #6 of 10 (permalink) Old 07-07-2009, 02:20 PM
My water pump was weeping a little until I upgraded the shaft to the new design.
insider is offline
post #7 of 10 (permalink) Old 07-07-2009, 02:35 PM
Perhaps they were trying to lighten the f4 a bit more. LOL.
MORT is offline
post #8 of 10 (permalink) Old 07-08-2009, 01:01 AM
That is the "weep" hole for the mechanical seal in the water pump. It gives coolant an escape point when the seal leaks somewhere besides into the engine. All bikes (and car) water pumps have that.
Slight seeping from the mechanical seal may stop as it beds in (new bikes or new pumps). Believe it or not, some manufacturers put "stop-leak" into the coolant on all new vehicles so customers don't get upset needlessly ( the good stuff is actually a lubricant that helps the mechanical seal bed in). You might try some of that before you replace the seal.
post #9 of 10 (permalink) Old 07-08-2009, 04:09 AM
X81
Is the correct answer. If left to get worse you'll end up with coolant in your engine.
X81 is offline
post #10 of 10 (permalink) Old 07-08-2009, 05:15 AM
MV05 EXY's Avatar
i thought this thread was gonna be better then this with that title.
MV05 EXY is offline
