1000 engine in 99 f4 750 track bike. - MVAgusta.net
 3Likes
post #1 of 12 (permalink) Old 11-10-2019, 08:50 AM Thread Starter
Hi. I have looked up various posts on engine swaps do have the basics that most are interchangeable but require a varying degree of other parts / work to complete
My f4 750 track bike is now actually going well. I posted about a year ago with handling issues and fuelling.
I now have Maxton front and rear and one of X bikes ECUs. The handling is still a little compromised but it’s good enough to track day and the odd race.
The power is now though a little low (circa 110bhp).
I’d like a 1000 but I’ve put thousands into this bike and do not want another bike in the garage as I dont have space.
I have a line on a 312 motor which send like the best one but also seems to have more variation than the generation 1 1000s.
As I have the motec eco and it’s not a road bike I think Chris will be able to getting the fuelling to work etc with my loom, maybe cutting and shutting a few connections etc.
I see the throttle bodies are larger on the 312, will my 750 bodies bolt on accepting that I’ll lose a bit of power (which I don’t mind) or do I need the 312 bodies and if so will they then fit my air box etc?
I am assuming I’ll need a new exhaust but is that correct? I’ve a standard 750 header with Sil silencers at present. I imagine I’d get better gains a with a 1000 race header but if I can start out with my exhaust and upgrade later that would spread the cost
I have a Febur race rad on mine. I’d like to swap that over as it was expensive!
I have a mechanical slipper clutch fitted in mine (really was essential for track riding), I would like to swap that in or will the motec Ecu co trail the 312’s bleed system?
Chris at X Bike’s has my bike at the minute and would do the swap if I went ahead with it. I am sure he could make it work what ever but I’d like to know in advance what I’m letting myself in for and also which motor would be the best donor when balancing what needs to be done vs performance.
I am not keen on the 910 option as the power gains are not significant enough to justify the cost.
My 750 motor is fine so this is a luxury not a need, but I feel I do ‘need’ the go of a 1000 🙂
I have asked Chris these questions as well and I’m sure he may have them all but I thought I’d ask the forum also as it seems you have done it all at some point!
Pat.
Me748 is offline
post #2 of 12 (permalink) Old 11-10-2019, 01:33 PM
312 motor wont work with your current Microtec ECU, you will need the complete loom from a 312 with its ECU!!
I have a 910 motor in my 750, even though on paper the power difference is small, in real life you cant compare them, the 910 engine will walk over the 750 engine in every aspect.....
esq'z me and theknurl like this.
ViggenF4 is offline
post #3 of 12 (permalink) Old 11-10-2019, 04:24 PM Thread Starter
Hi. I think if my motor had blown and I had to change motor the 910 would be a good option if one came up at the right price but I fancy the oompth of a 1000.
I thought the microtec ECUs were essentially the same and could be programmed for various bikes but that was only an assumption.
Is it the 312 that’s more of a problem, would an earlier 1000 be more compatible?
As I mentioned I have asked Chris the same questions and I’m sure he will have chapter and verse on the matter
He did a great job on my 750 and always has time to talk anything MV.
Pat.
Me748 is offline
post #4 of 12 (permalink) Old 11-10-2019, 10:40 PM
Your ECU wont work with the 312 loom. Early 1000 with 16M, it will.
ViggenF4 is offline
post #5 of 12 (permalink) Old 11-11-2019, 06:06 AM
Your 750 slipper clutch won't work on a 910 or 1000 motor.......
The mainshaft on the later motors is 2mm larger......you could split the cases and change the bearing
But the primary ratio is different on the later motors
post #6 of 12 (permalink) Old 11-11-2019, 03:41 PM Thread Starter
Not looking so positive for the motor swap!
I would be happy with an early 1000 motor which my ecu seems likely to fit. The expense of another slipper clutch adds to the cost though.
The stm slipper clutch kit I have to my Evo 1 was originally for the Evo 2/3, the threaded end of the input shaft is different between the Evo 1 and 2/3. The former being 25mm and the latter 22mm.
STM were helpful and able to provide parts to make the clutch I had fit my bike. I dont know enough about the differences between the 1000 and the 750 but I wonder if STM could supply parts to make it fit.
I’ll see what else people feel needs to be swapped out for an early 1000 rather than the 312 which seems like a step too far, but already the additional work / unknowns is beginning to build into what I would call a fools errand!
Me748 is offline
post #7 of 12 (permalink) Old 11-11-2019, 10:09 PM
For early 1000, its straight swap. Just map the ECU.
ViggenF4 is offline
post #8 of 12 (permalink) Old 11-12-2019, 03:19 AM Thread Starter
Thanks Veggen. Just the slipper clutch that won’t transfer then.
I’ll keep an eye out for a 1000 motor in the UK (you don’t see many!)
Pat
Me748 is offline
post #9 of 12 (permalink) Old 11-12-2019, 06:40 AM
Once in a while complete crashed bike appears, would be a good donor for you.
Hope you find what you looking for!
ViggenF4 is offline
post #10 of 12 (permalink) Old 11-19-2019, 07:02 AM
X81
No you don't. The M232 that i use to replace the 16M ecu allows conversion to sequential injection. Data is data so we can copy that across and fill in any fields that differ slightly. Sensor calibrations are the same.
You can do this conversion with only the addition of 2 parts. Throttle bodies for injector size and exhaust system due to potentially taller engine. The only part you'll not be able to run on the conversion will be the EBS system as the std wiring loom has no facility for it, the 1000S does though so you could upgrade a 1000S fully to 312 spec.
Nito likes this.
X81 is offline
