New F4 Question - Page 2 - MVAgusta.net
post #11 of 15 (permalink) Old 06-28-2009, 12:37 PM
I ordered the impeller and Muzzy fan blades. I want to diminish the heat output before I do anything else. Once I put those in/on I'll look at more power. More power won't do anything for the bike if it runs hotter as a result. I may also add the third fan as outlined in one of the threads here.
number2 is offline
post #12 of 15 (permalink) Old 06-28-2009, 01:58 PM Thread Starter
Send a message via MSN to spegr
I'll do that....Im in central MS, over by Meridian. I guess that makes two F4's then where do you take yours to get serviced?.........be safe over there.
spegr is offline
post #13 of 15 (permalink) Old 06-28-2009, 02:00 PM Thread Starter
Im ordering the fan blades and impellor today....thanks. But has anyone else noticed "brake fade" on the F4 when you really get on them hard? There has to be a brake upgrade or better pucks?
spegr is offline
post #14 of 15 (permalink) Old 06-28-2009, 05:07 PM
Yup, Radial Brembos and then monoblock Radial Brembos.
Requires replacing the ends of your forks, look at a 312 or RR for how they look.
The Nissin gear isn't rubbish, yes it will fade a bit if you hammer them, but is really quite good. You may be in need of some new pads. As your bike has done few miles, you may have air or moisture in the brake fluid. Cheapest thing to do first is to replace the fluid and bleed the brakes.
yo_clarkie is offline
post #15 of 15 (permalink) Old 06-30-2009, 08:26 PM
"Brake pucks"... Meridian MS... Are you a T-45 mechanic?
ducgsxr is offline
