Need quick advice how to change coolant - MVAgusta.net
post #1 of 7 (permalink) Old 06-27-2009, 06:25 PM Thread Starter
Timster's Avatar
hey guys, just a quick question. I want to change the coolant to engine ice tonight. I read in the owners manual how to remove the key cover to fill the coolant but where's the plug to get rid of the cold coolant? sorry if thats a dumb question.
thanks, tim
__
MV F4 1000 S Red/Silver
HUSABERG FS 570
Timster is offline
post #2 of 7 (permalink) Old 06-27-2009, 06:39 PM
Debrun's Avatar
It's on the left side, there's a nut on the bottom of the water pump. Someone posted a picture recently but I cannot find it. You'll be wanting a torque wrench too. As I understand the best way to drain it is to leave the bike on the side stand. Make sure you flush out the old stuff with distilled water before adding the Engine ice.
If you search, Coolant, drain, water pump, the old thread should pop up somewhere within the results.
edit: I think your brutale manual should show the location of all the fluid in and out points.
Debrun is offline
post #3 of 7 (permalink) Old 06-27-2009, 06:46 PM
ASM
ASM's Avatar
He actually have a F4 1000S though...
Ciao, Andreas
ASM is offline
post #4 of 7 (permalink) Old 06-27-2009, 06:47 PM
Debrun's Avatar
DOH!!!
Debrun is offline
post #5 of 7 (permalink) Old 06-27-2009, 07:44 PM
Quick advice?
Drain the old stuff from the bottom. Fill it with the new stuff from the top.
There is a bolt under the water pump housing. unscrew that and the coolant will squirt out.
post #6 of 7 (permalink) Old 06-27-2009, 09:23 PM
khameron's Avatar
have a look at the 2nd video on the NIWI's page.
Right at the beginning of the video, you will see exactly what bolt is unscrewed to bleed the coolant out of the bike.
http://www.mvagusta-vesuvio.com/view...er--NIWI-.html
khameron is offline
post #7 of 7 (permalink) Old 06-27-2009, 09:43 PM Thread Starter
Timster's Avatar
wow. thanks a lot. really nice video. i think i'm gonna order a niwi soon. seems not too difficult to install. thanks for taking the time to make the video.
__
HUSABERG FS 570
Timster is offline
