May Have Lost Engine - Page 3 - MVAgusta.net
 9Likes
post #21 of 29 (permalink) Old 08-25-2019, 01:17 AM
ViggenF4's Avatar
Depending of do you have spark in any cylinder? I would start with few things first.
- Ignition fuses
- Crank sensor resistance values
- TPS sensor values, yes it should not affect spark, but has done that to me
- Measure the coils (did the 2007 have twin pack of coils?)
- Check the ECU ignition wise
- And of course main wiring harness comes to mind
Have you checked the oil allready???
ViggenF4 is offline
post #22 of 29 (permalink) Old 08-25-2019, 01:20 PM
Originally Posted by ericfreeman View Post
Any advice from you electrical gurus will be very much appreciated.
First pice of advice is to put your bike model and year in your signature line so the we donít have to dig through pages of thread in order to figure out which wiring diagram and troubleshoooting guide to reference
post #23 of 29 (permalink) Old 08-25-2019, 03:40 PM Thread Starter
ericfreeman's Avatar
Problem found, and it's not good. While checking the crank sensor (tested good) I realized I hadn't bothered to look down the throttles to inspect the valves. Well, No. 4 intakes are bent to hell and none of the other valves are moving when cranking the engine! Turns out my original diagnosis of failed cam chain/sprocket bolts was spot on! Don't know exactly what failed yet as I'm not digging any further at this point. Anyway, will reassemble everything and park the bike until winter arrives and I have time to yank the motor and strip it down. Really disappointed in MV at this point: easy 12k on the motor, great maintenance and yet it craps out on me big time. Definitely will discourage anyone I know or meet of every buying an MV product. Can only guess how difficult it will be to get the parts I need (I live out in the PNW farmland) and what they will cost. Time to get on one of my vintage Sportsters and go for a ride on something that actually runs!
Thanks for all your advice, only wish it had been something simple.
Eric
ericfreeman is offline
post #24 of 29 (permalink) Old 08-25-2019, 06:24 PM
Edward's Avatar
early models had an issue of an airbox wellnuts getting loose and dropping into the engine...
MV Agusta FAQ: Wellnuts on airbox need to be replaced at every removal!
back in 2005:
"There have been at least two engine failures documented online due to airbox wellnut disintegration. The factory requirement is to replace the airbox wellnuts each time the covers are removed."
E d w a r d B4910s08
Public Service Announcement
(Forum Introduction Thread)
Location: Tools > User CP > Your Profile > Edit Your details > Additional Information > Location
Bike Model/s: Tools > User CP > Settings & Options > Edit Signature
Edward is online now
post #25 of 29 (permalink) Old 08-25-2019, 08:18 PM Thread Starter
I replaced the wellnuts with aluminum rivnuts a long time ago so that wasn't a factor. Definitely believe the cam sprocket bolts are the culprit here since I read another account of this happening to another 2007 F4 owner.
post #26 of 29 (permalink) Old 08-29-2019, 02:16 PM
Rob Caso's Avatar
back in 2005:
I never, ever would have thought of this one. I immediately walked out to the AGO and sure enough, two screws on ea side with 14 year old well nuts presumably holding them in.
Now I have to take the thing apart. Again
Thanks for posting this one. I gotta borrow up some common sense.
RC
Failure is not an option
2016 Tri Thruxton R
2005 Ago F4 1000
2005 BMW 1200GS
1995 Duc 916
1994 Bim DB2
1986 Duc MHR Mille
1983 BMW R100S
1975 Hon 400
1975 BMW R90S
1974 Duc 750 Sport
1972 Hon 750
1966 Hon S90
1965 Duc Monza
1971 Norton 750
1971 BMW R75
Rob Caso is online now
post #27 of 29 (permalink) Old 08-29-2019, 08:59 PM
Edward's Avatar
This why this forum is great for the MV collective. Glad the link was helpful.
On the side... I went out on my Brut today for a reprieve. Came across a down biker. He got clipped at an intersection in Philly. Please remember if anyone on this forum sees a biker down please stop and offer support. It goes a long way...
post #28 of 29 (permalink) Old 08-30-2019, 01:44 AM
Rob Caso's Avatar
Hate to hear this stuff. I stopped just the other day for a guy on a newish Harley pushing his bike. He had run out of gas but had some coming.
The shocker was that he didn't make his girlfriend help push.
What's wrong with some people?
RC
2016 Tri Thruxton R
2005 Ago F4 1000
2005 BMW 1200GS
1995 Duc 916
1994 Bim DB2
1986 Duc MHR Mille
1983 BMW R100S
1975 Hon 400
1975 BMW R90S
1974 Duc 750 Sport
1972 Hon 750
1966 Hon S90
1965 Duc Monza
1971 Norton 750
1971 BMW R75
post #29 of 29 (permalink) Old 08-30-2019, 04:33 PM
I posted a thread "Avoiding Wellnut Disasters "
You need 2 M4 Rivnuts........put them in the rear holes
McMaster-Carr part #94020A371
Tags
engine cut off
