Help.....Slipper clutch problems - MVAgusta.net
post #1 of 2 (permalink) Old 06-22-2009, 06:50 AM Thread Starter
Michel Canino's Avatar
I have fitted the slipper clutch on the F4 and I also have replaced the levers with the CRG ones.
On my last track day after 10 laps my clutch lever didn't work anymore, it became very soft and I couln't shift down any gear. I slow down and slowly the clutch start working again. I quite sure now and with the help of G. Rand that the clutch is properly fitted.
It looks like the clutch became very hot and when it cool down everything went back to normal.
My questions are:
- Do you think it's because I have to purge the hydraulic ?
- Do I have to fit back the original clutch lever ????
- Do I have to remove everything again ?????
I need your help guy's
Michel
Michel Canino is offline
post #2 of 2 (permalink) Old 06-22-2009, 09:02 AM
I would look closely at where the clutch lever engages engages the plunger of the master cylinder. If your new lever is not depressing the plunger the clutch won't engage (disengage?) and you won't be able to downshift.
