2008 F4 fuel tank question - MVAgusta.net
 5Likes
post #1 of 13 (permalink) Old 05-05-2019, 01:18 PM Thread Starter
steved57's Avatar
Ok - So I go to start my MV couple days ago and when I turned on the key it sounded like a dishwasher inside the fuel tank and the bike wouldn't start so I figure bad hose or hoses on the fuel pump - So I get tank off bike and remove fuel pump and yes the hose between the pump and filter
is rotten - so I change the hoses and filter and all good BUT I have a question in that the service manual and everything I can find shows the tank has a threaded hole in corner with a bolt and copper washer to drain tank etc..... Mine doesn't as it has a hose coming from an evaporative cannister that is inside the tank and that hose has a threaded stud (and the stud has a hole thru it and a hex in the end for an he wrench) sticking thru hole with a locknut on it
So my main question is - has anyone seen this or their bike have the same set up - is there an o ring or gasket on the flange on the threaded stud ?
If there was one I didn't see or find it but would sure think there would need to be one - any thoughts or suggestion would much be appreciated
I do not want to put it all back together and have a leak there
See attached pictures
2008 MV Agusta F4 312R
2018 KTM 300XC
2010 KTM RC8
2003 Yamaha TZ 250
2019 KTM 350 SXF
2015 KTM 690 Enduro R
2017 KTM 1290 Super Duke GT
1974 Suzuki T500 Titan
1974 Honda CB 550-4
1970 Suzuki TS50 Maverick
2010 Harley Davidson XR 750 flat tracker
steved57 is offline
post #2 of 13 (permalink) Old 05-05-2019, 02:28 PM
There should be a grommet (washer) inside the tank.
That is the standard USofA tank for first generation bikes.
nigelrb likes this.
post #3 of 13 (permalink) Old 05-05-2019, 03:09 PM Thread Starter
steved57's Avatar
Ok Thanks Silentservice as I couldn't find that page with the grommet
Any idea if it's an item I'll be able to order ? Or if it's something I can source locally and i wonder if it's rubber or viton etc....
2018 KTM 300XC
2010 KTM RC8
2003 Yamaha TZ 250
2019 KTM 350 SXF
1974 Honda CB 550-4
steved57 is offline
post #4 of 13 (permalink) Old 05-05-2019, 04:42 PM
Grommet is an O-Ring !! go to your hardware store and buy one. Any fuel resistant o-ring material will be fine.
post #5 of 13 (permalink) Old 05-05-2019, 05:09 PM
Rob Caso's Avatar
Use Viton only for such an application
RC
Failure is not an option
2016 Tri Thruxton R
2005 Ago F4 1000
2005 BMW 1200GS
1995 Duc 916
1994 Bim DB2
1986 Duc MHR Mille
1983 BMW R100S
1975 Hon 400
1975 BMW R90S
1974 Duc 750 Sport
1972 Hon 750
1966 Hon S90
1965 Duc Monza
1971 Norton 750
1971 BMW R75
Rob Caso is offline
post #6 of 13 (permalink) Old 05-06-2019, 06:21 AM
Nitrile (Buna-N) is also an acceptable material. As I recall, when I did mine, it ws a fiber washer...but that was a long time ago.
Were it me, I'd be looking for a Viton or Nitrile (Buna-N) O-ring of compatible size.
But, before I did that.....I'd look inside my fuel tank to see if the original "grommet" is in there....
esq'z me likes this.
post #7 of 13 (permalink) Old 05-06-2019, 10:59 AM Thread Starter
steved57's Avatar
I appreciate all the help and replies guys - I know I'm not on here much but this site rocks and the info available is incredible
I have looked inside the fuel tank and I even strained the oil from my drain pan that I pour the last little bit of fuel into but nothing there
I'm planning on using a viton o ring as we have a good o ring store here in town
Thanks again everyone
2018 KTM 300XC
2010 KTM RC8
2003 Yamaha TZ 250
2019 KTM 350 SXF
1974 Honda CB 550-4
steved57 is offline
post #8 of 13 (permalink) Old 05-06-2019, 08:38 PM Thread Starter
steved57's Avatar
Okay so I found the o ring in my shop vac as I had cleaned fuel tank while pump assembly was removed and there was a small amount of grit in tank which I vacuumed out - so I'm good to go !! Getting ready to reassemble now
Again I would like to say thanks to those who chimed in
esq'z me and silentservice703 like this.
2018 KTM 300XC
2010 KTM RC8
2003 Yamaha TZ 250
2019 KTM 350 SXF
1974 Honda CB 550-4
steved57 is offline
post #9 of 13 (permalink) Old 05-06-2019, 10:04 PM
MV Arthur's Avatar
Great news! I'll delete my post. Sorry about that.
2009 F4 RR 1078 312
2005 F4 Tamboweenie
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
MV Arthur is online now
post #10 of 13 (permalink) Old 05-08-2019, 11:04 AM
Edward's Avatar
Sidebar :
Isn't that dangerous to do in general? Fumes can ignite while passing through your vacuum, no?
E d w a r d B4910s08
PUBLIC SERVICE ANNOUNCEMENT
1.
(Forum Introduction Thread)
2. Include your LOCATION in your profile: Tools > User CP > Your Profile > Edit Your details > Additional Information > Location
3. Include your BIKE MODEL/S in your signature: Tools > User CP > Settings & Options > Edit Signature
4.
Special thanks to forum member Donsy
Edward is offline
