Got the PCIII working. Now a map question =) - MVAgusta.net
post #1 of 2 (permalink) Old 06-20-2009, 11:24 PM Thread Starter
cryptyk's Avatar
I got the PCIII working, with many thanks to Odonata. It sounds obvious after hearing it, but you can tell which cylinder isn't firing by seeing which header pipe isn't getting hot. Thanks Odonata!
So now the setup is Bodis slipon, Bodi midpipe and BMC air filter.
Now a question: Should I just use the zero map until I get to the dyno for tuning? Or should I choose one of the following:
- Stock map
- the closest one I can download from Powercommander.com (which is: European "AGO" Model, RG3 racing slip on and stock link pipe (catalytic converter removed), Stock or aftermarket air filter, Stock EPROM)
Or does someone else here have the same setup and want to share a map?
cryptyk is offline
post #2 of 2 (permalink) Old 06-21-2009, 12:29 AM
MV Cellist
odonata's Avatar
Send a message via Yahoo to odonata Send a message via Skype™ to odonata
Congrats no getting it to work finally! I would say to try both but I imagine the AGO set up is closer to what you have at the moment. Best of luck!
O D O N A T A
odonata is offline
