Help!! Gen 1 decisions... - Page 13 - MVAgusta.net
 69Likes
post #121 of 127 (permalink) Old 08-21-2019, 01:11 PM
Originally Posted by Nito View Post
Thanks, just one more question then! Does the 1078 riding experience out do the Tambo?
After putting a few hundred miles on her I'm not convinced that the TSS and EBS work well enough in unison to eliminate the need for a slipper clutch. The 1078 312RR is notably more stable/smooth when I downshift. I'm going to install a TSS (not Torque Shift System) slipper I picked up. I installed a set of Motocorse Evoluzione ti slip ons and the RG3 eprom that came with the bike works fine with it. The bike is louder and has a much more exotic low end gurgle.
Nito likes this.
MV Arthur is offline
post #122 of 127 (permalink) Old 08-22-2019, 03:00 AM
I think.you might find it is the way the ECU works that is causing the downshift issues.
It can only switch the ebs / fuel cut on or off where as the 1078 ECU can ramp everything up or down smoothly so you don't notice.
If you are not upgrading the ECU then the best thing is to eliminate the fuel cut during off throttle together with the ebs ....then it will be smooth as !
esq'z me, theknurl and Nito like this.
merc07 is offline
post #123 of 127 (permalink) Old 08-22-2019, 08:11 AM Thread Starter
The Tambo is on the earlier ecu isn't it? As in the 16m not the 5m?
Thanks for the feedback, the EBS system fascinates me. I was having an interesting chat with Chris at Xbikes the other day (specifically on the Microtec M226 -5m replacement-), he was telling me it can be set up like a two stroke or a v-twin and anywhere in between. Clever stuff really.
Motocorse Ti slip ons, worthless without pics From what I've seen on you tube they're the best sounding I have come across, saw a vid of these on a Senna, enjoy
Nito is offline
post #124 of 127 (permalink) Old 08-22-2019, 08:22 AM
It's not an issue, just different. I likely won't go past the slipper clutch in looking for the qualities of the 312RR. I have a Microtec but don't feel the need so far.
post #125 of 127 (permalink) Old 08-22-2019, 08:32 AM
Nothing really super special about them visibly. They look pretty similar to RG3's. They're super light.
Nito likes this.
post #126 of 127 (permalink) Old 08-22-2019, 08:36 AM Thread Starter
They look lovely to me; is it fitting that this lovely Tambo is sitting in a jewellers
MV Arthur likes this.
Nito is offline
post #127 of 127 (permalink) Old 08-22-2019, 08:48 AM
Thanks. And yes, it's a 1.6M.
