Help!! Gen 1 decisions... - Page 12 - MVAgusta.net
 69Likes
post #111 of 127 (permalink) Old 08-01-2019, 10:21 AM Thread Starter
I guess that's mainly ride height adjustments then. Incidentally, aren't the Brembo's you have currently, generally regarded as being better than the 6 pot Nissin's anyway?
Also must apologise about the sideplates/swingarm comment, I don't know why I thought the Tambo's were gold, of course, they're not!
ps. Nigel, someone bought the Bike Specialists dearer Tambo of the two it would appear!
Nito is online now
post #112 of 127 (permalink) Old 08-01-2019, 10:35 AM
MV Arthur's Avatar
I never said I was going to install them lol. I'd like to possess the original parts. The oem Tambo rotors are different as well.
2009 F4 RR 1078 312
2005 F4 Tamboweenie
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
MV Arthur is online now
post #113 of 127 (permalink) Old 08-01-2019, 10:38 AM Thread Starter
Yes I clocked them, well, in the very rare chance I see any of the parts you're after in passing I'll be sure to let you know!!
MV Arthur likes this.
Nito is online now
The Following User Says Thank You to Nito For This Useful Post:
post #114 of 127 (permalink) Old 08-05-2019, 09:21 AM
Al-
Al-'s Avatar
Originally Posted by MV Arthur View Post
Perhaps someone with more intimate knowledge of the suspension components can chime in but the front geometry can be altered with a few different parts, and I see quite a few differing part numbers from my 1078RR. The rear shock/connecting rods are very different on the Tambo as well, affecting the rear geometry. The OEM front tire is a 65 series, which I didn't know either. I thought all the 1000 F4's used 70 series tires in the front. As I go through her I'm noticing many differences. For example, it doesn't use wellnuts on its modified airbox (for the TSS I'm assuming). There's just a small hole for the panel bolt and it's threaded on the intake side.
All of the early 750 F4s had the steeper steering head support, and came oem with the 65 series front tire. The tambo was an early 1000, so its possible it had some aspects of the early 750 but I am not an expert. What i have noticed is that the mag frame plates appear to have two holes compared to the single hole on the aluminum plates for the shock pivot bolt. I assume some alteration is possible here, but would require a different height adjuster, so that may be the case. I'd be interested in looking at the tambo airbox more closely, I had done some previous design work to play with updated the early F4 with the TSS from the 2010+ but I lost my CAD files when my old company's computers were hacked a few years ago.
2006 Brutale 910S
2012 F4 RR
2012 F4 RR
Al- is offline
post #115 of 127 (permalink) Old 08-05-2019, 01:11 PM
MV Arthur's Avatar
Sure, we can pop it off at the gap if you want. Or whenever you're in NYC.
2009 F4 RR 1078 312
2005 F4 Tamboweenie
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
post #116 of 127 (permalink) Old 08-06-2019, 11:57 AM Thread Starter
According to the workshop manual the Tambo should have a 70 profile front!?!
Nito is online now
post #117 of 127 (permalink) Old 08-08-2019, 07:24 PM
MV Arthur's Avatar
Maybe it's a regional thing. I'm pretty sure I saw 65 somewhere. Could be wrong...
2009 F4 RR 1078 312
2005 F4 Tamboweenie
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
post #118 of 127 (permalink) Old 08-08-2019, 07:38 PM
750's use the 65....everything else uses 70s.... I use a 70 on my SPR, but I did have to make some brackets to raise the fender so it wouldn't rub at the leading edge.
post #119 of 127 (permalink) Old 08-08-2019, 10:47 PM
MV Arthur's Avatar
Saw it here. https://www.motorcyclespecs.co.za/mo...00_ta%2004.htm
2009 F4 RR 1078 312
2005 F4 Tamboweenie
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
post #120 of 127 (permalink) Old 08-09-2019, 04:03 AM Thread Starter
Here you go, straight from the workshop manual
attached.
Nito is online now
