Clutch differences - MVAgusta.net
 3Likes
post #1 of 15 (permalink) Old 09-20-2018, 04:06 PM Thread Starter
ViggenF4's Avatar
Clutch differences
What is the main difference between the clutches, brutale uses four springs and F4 six, but are they otherwise interchangeable?
ViggenF4 is offline
post #2 of 15 (permalink) Old 09-20-2018, 10:26 PM
Depends on year and actual model, but most of the clutches will interchange as long as primary gear ratio is the same. The transmission shaft is the key. If that part is the same and the primary tooth count is the same then the clutch fits.
post #3 of 15 (permalink) Old 09-20-2018, 10:54 PM
750 clutch baskets only fit 750s......the primary gear ratio is different
Slipper clutch hubs are a larger diameter and have a different number of teeth, so early
friction plates won't fit
Ask me how I know.....I bought a slipper without plates or discs
The splines on all mainshafts are the same
I have an SPR gearbox (750) in my 1000S with a late slipper clutch
It's coming out and going in my '08 motor with an '09 head
I just did a thread about transmission ratios, it's in the 4 cylinder section
post #4 of 15 (permalink) Old 09-21-2018, 12:07 AM
Edward's Avatar
A n i m a l !
nigelrb likes this.
E d w a r d B4910s08
PUBLIC SERVICE ANNOUNCEMENT
1.
(Forum Introduction Thread)
2. Include your LOCATION in your profile: Tools > User CP > Your Profile > Edit Your details > Additional Information > Location
3. Include your BIKE MODEL/S in your signature: Tools > User CP > Settings & Options > Edit Signature
4.
Special thanks to forum member Donsy
Edward is offline
post #5 of 15 (permalink) Old 09-21-2018, 12:11 AM Thread Starter
ViggenF4's Avatar
Thanks again.
I was afraid it might be so, cos i bought an 910 brutie motor without the clutch..... Just have to source an 910 complete clutch then. Visually they look the same, not including the spring count.
Was thinking of putting my 750 F4 box on it, but since its so low mileage motor, i best stick with the box it comes with, and buy a complete stock clutch.
ViggenF4 is offline
post #6 of 15 (permalink) Old 09-21-2018, 12:25 AM
Originally Posted by Edward View Post
A n i m a l !
No...... I just want things my way......
Probably take 6th gear out of the SPR box and put a standard 6th in.....
Close ratio 5 speed with overdrive
Why not?
post #7 of 15 (permalink) Old 09-21-2018, 12:39 AM
Thanks again.
ViggenF4;
Please pay attention.....
https://www.mvagusta.net/forum/153-g...on-ratios.html
Your 750 and the 910 have the same transmission......
Any 910, 1000 or 1078 1st Gen clutch will work the later ones will be slipper clutches
The parts might not interchange, but the entire clutch will drop right on
Enjoy
post #8 of 15 (permalink) Old 09-21-2018, 12:52 AM Thread Starter
ViggenF4's Avatar
So i cant use my 750 F4 clutch on the 910 engine... I got it now i think.
ViggenF4 is offline
post #9 of 15 (permalink) Old 09-21-2018, 11:46 AM Thread Starter
ViggenF4's Avatar
Bought an complete 910 clutch of Ebay for 68 euros. So thats sorted!
Next is the starter, the 910 uses the later starter, and it does not come with it either, so does my old 750 starter do the job?
ViggenF4 is offline
post #10 of 15 (permalink) Old 09-21-2018, 11:33 PM
ViggenF4;
Now you're getting it, your 750 clutch basket won't work
Your 750 starter is probably identical, just lube the O-ring and stick it in
Retorque the oil pan bolts while it's easy
You'll need to change the rear water manifold, oil filter mount and add the stupid heat exchanger
Inspect the valves and reseal the F4 cover and both sides of the valve cover....I know
what the manual says.....fuck them.....want to do it twice????
Inspect the vacuum lines to the throttle bodies for cracks
BE VERY CAREFUL OF THE FUEL INJECTOR CONNECTORS , THE ARE VERY EASY TO BREAK
ON THE INJECTORS
