Brand New Battery Issues - Page 3 - MVAgusta.net
 22Likes
post #21 of 100 (permalink) Old 08-01-2018, 08:17 AM
Reading that again...it is true that the start signal goes through the dash.
post #22 of 100 (permalink) Old 08-01-2018, 10:26 AM
That 7 indicates you, in fact, have a 2007 built bike. I suppose they could have carried over a 2006 harness.
OR...the 2007 electrical drawing is wrong.
US market bikes are a year behind other markets....My 910R is a uS 2008 model (VIN confirms) but was a 2007 in Europe, etc.
So that may help explain???
post #23 of 100 (permalink) Old 08-03-2018, 11:33 AM Thread Starter
Send a message via AIM to whobeyou Send a message via Skype™ to whobeyou
Well, I've traced back to everything I could. I'm not the best with electrical diagrams, but I followed everything to the best of my ability. No fuses have been popped at all, and I can't see any burnt wiring/corroded connections. I'm stumped. I think I'm going to try and swap the battery for a known good one(maybe I killed a cell?), and after that maybe start trying to find an ECU.
Thoughts?
-whobeyou
Bikes:
2006 Ninja ZX10R (Sold)
2008 Streetbob (Sold)
1999 Ninja ZX9R (Sold)
2005 ZX10R (Wifes!)
2007 MV Agusta F4 1000R
1981 KZ1000CSR
whobeyou is offline
post #24 of 100 (permalink) Old 08-06-2018, 10:04 PM
whobeyou;
There is an excellent electrical trouble shooting guide in the Factory manual......check it out
post #25 of 100 (permalink) Old 08-07-2018, 06:52 AM
@whobeyou: Please list the concise symptoms you currently have with 1. Key off 2. Key on 3. Start button pressed
post #26 of 100 (permalink) Old 08-15-2018, 04:39 PM
DKDravis's Avatar
Cool It was the solenoid ..
Back to resurrect the "starter" thread..
The starting problem I had was indeed a faulty starter solenoid -- Root cause was something else though. Apparently the 40AMP fuse had been badly seated in the fuse holder part on the solenoid, causing it to warm up and melt the plastics around it .. I bought a new Yamaha part () and the problem was solved.
My question now is: The original main fuse on my 750SR seems to have been a Pink 35Amp fuse ? Never seen one of those before - At least that was what was in the spare fuse holder, in the live holder was a red 40AMP - The plastic on the fuse was almost completely melted, but the fuse was not blown
The Yam Solenoid came with 30AMP Green fuses .. I put the 35AMP one in, bike seems to run just fine with that..
Question now is: Which one is the correct size Fuse for my SR? -- 30-35 or 40AMPS ?? Not much info in the manuals I have .. . "Replace fuse with the correct value"
"There is no law of Nature, requiring the Universe to make sense"
"103% of all people do not understand Statistics"
"Sapere Aude -- Dare to KNOW!"
-- DKDravis --
DKDravis is online now
post #27 of 100 (permalink) Old 08-16-2018, 12:49 AM Thread Starter
@silentservice703, Now when I turn the bike on, the Neutral, Battery, and Oil lights remain on, no activity on Tac or Speedo, no headlight/tail-light. The General Feed relay buzzes the whole time as well.
-whobeyou
Bikes:
2005 ZX10R (Wifes!)
1981 KZ1000CSR
whobeyou is offline
post #28 of 100 (permalink) Old 08-16-2018, 08:51 AM
@whobeyou: What is the voltage in the system at the time of KEY ON?
post #29 of 100 (permalink) Old 08-16-2018, 08:55 AM
@DKDravis: 40 amps is correct.
I'd clean all of the electrical contact points for the solenoid and ensure tight connections.
post #30 of 100 (permalink) Old 09-30-2018, 08:38 PM Thread Starter
Sorry for the late reply. Going through some personal things at the moment.
I just got the bike back from Fay Myers yesterday. They let me know that I didn't have a ground hooked up on the battery. I'm not really sure how I could miss something like that, but the bike is now responding. The technician there (who seemed very knowledgeable about the F4 in particular as he has 2 of them) told me his bike had done the exact same thing and it was the diode.
The Symptoms:
I turn the key on, and everything sounds like it's working. I hear the fuel pump, and the tac needle goes all the way up, and back down. I can now read the mileage and whatnot also. However when I push the start button, nothing. I've checked that the bike was in neutral and I'm holding the clutch while trying.
I've charged the battery overnight just to be sure, and nothing still. I had the wife come hold the clutch and I've jumped the starter relay. The bike turns over, but does not start. Thus the starter seems to be OK. I'm not hearing any clicking or anything from the starter relay when pressing the start button. Both 40A fuses on starter test OK.
From what I've been reading, I thought that when you have a blown diode, your bike wont light up at all. Correct me if I'm wrong though. I'm going to order some of the diodes tomorrow and will switch it out just to be sure. Let me know if I'm completely off base about the blown diode symptoms
-whobeyou
Bikes:
2005 ZX10R (Wifes!)
1981 KZ1000CSR
whobeyou is offline
