Dead battery ?? - MVAgusta.net
post #1 of 5 (permalink) Old 06-08-2009, 11:12 AM Thread Starter
cooper3309's Avatar
Dead battery ??
OK heres the deal. I transplanted a 1000 into my 750 and had to change the harness, ECU, the whole kit and caboodle. Well, everytime I leave the bike sit for any amount of time the battery goes dead. I've replace the battery once already and I'm getting kind of pissed . Has anyone else had problems with thier 1000R's losing the charge and what was the culpret ? Is there someplace I should start looking first for this gremlin ?
Thank you in advance
Cooper
01 750S W/1000R engine
01 Ducati 748 W/853 kit
03 Yamaha R1 (SOLD)
01 Kawasaki KX 125
88 Yamaha YSR 50
01 Yamaha R6
03 Suzuki DRZ pitbike
1982 Honda 110 atc
Yamaha PW50
1978 Honda 90 atc
2011 Yamaha Grizzly 700
2008 Yamaha Raptor 660
1975 Kawasaki G5 100
cooper3309 is offline
post #2 of 5 (permalink) Old 06-08-2009, 06:54 PM
Check your key off current draw. Should be just a milliamp or so (meter/clock). Look for the reason if it is excessive (leaky diode in rectifier or similar). If it isn't excessive then you just got crappy batteries.
post #3 of 5 (permalink) Old 06-09-2009, 12:04 AM
haupti's Avatar
Can You specify "any amount of time" ? I experienced on my F4's that the batteries are discharged after around three to four weeks. And this so far that they are considered not chargable. So I bought probably around ten batteries in my first years of owning a F4. Since a few Years is my F4 constantly on a charger when ever it is in the garage. So that was the best money spend so far and would probably help You as well. But what is consuming power when the bike is switched off ?
haupti is offline
post #4 of 5 (permalink) Old 06-09-2009, 02:09 AM
Banned
with the 312R I had a 2/3 week max then dead I had the data tool alarm on it and put it down to the alarm drawing current
My EV03 had the same Data tool system 4 alarm and I could get 2 - 3 months life before going flat so the short term answer is a good trickle charger. There has to be something drawing juice through the 312 and with both bikes having same alarm I cannot point the finger at the alarm system especually when others with the 1000 are having same problems.
http://mvagusta.net/forum/showthread...attery+charger
F41NXS is offline
post #5 of 5 (permalink) Old 06-09-2009, 03:03 AM
My 1000S is approaching 4 years old now, I have the Datatool S4 alarm fitted and I'm still on the original battery although I do use an Optimate battery tender.
Keep one wheel down!
No MV's in the garage anymore
john is offline
