Why a race ECU? - MVAgusta.net
post #1 of 17 (permalink) Old 06-04-2009, 04:12 AM Thread Starter
RT1
RT1's Avatar
Why a race ECU?
done i bit of reading and cant figure out why i should change to a race ecu on the 312r..... my plan it to change the slipons, install a PC3 and BMC filter, then get it remapped on a dyno......can anyone tell me why i should get the race ecu as well? i thought that was the job of the pc3 to tune it in.........
RT1 is offline
post #2 of 17 (permalink) Old 06-04-2009, 04:54 AM
Snohman's Avatar
i'd have to wait for the experts to "tune in" my guess is that it would provide a better starting point before fine tuning and remove the so called flat spot around 5000rpm
Snohman is offline
post #3 of 17 (permalink) Old 06-04-2009, 05:41 AM
MV-999R's Avatar
Because you have to get rid of the lambda sensor to use the PC3 and the OEM ECU always tries to read the lamba sensor first.
MV-999R is offline
post #4 of 17 (permalink) Old 06-04-2009, 07:15 AM
wa2fst's Avatar
so is that why my lambda sensor was unplugged by the tuner? i got mine back and was looking for my mysterious leak and see it was unplugged.
wa2fst is offline
post #5 of 17 (permalink) Old 06-04-2009, 07:28 AM
hb88xx's Avatar
or disable the Lambda by substituting by a plug or emulator. Else the PCIII is being compensated.
4,5Mg~3Al~2Ti~Fe
hb88xx is offline
post #6 of 17 (permalink) Old 06-04-2009, 07:29 AM
MV-999R's Avatar
As long as you have the race ECU you don't actually need to take off the lambda sensor since the ECU won't read it, but why leave it there if you're not using it? I have also removed the lambda sensor when i installed the race ECU.
MV-999R is offline
post #7 of 17 (permalink) Old 06-04-2009, 08:21 AM Thread Starter
RT1
RT1's Avatar
ok, but will the pc3 still work at all without the race ecu?
RT1 is offline
post #8 of 17 (permalink) Old 06-04-2009, 08:39 AM
Not according to DynoJet. The 5SM ECU does not respond to the lamda sensor eliminator that DynoJet sells. It is looking for a constantly varying signal to let it know the sensor is working. Goes to a default mode if failure detected (i.e.: no proper signal).
DynoJet now producing PC V for those bikes in this catatgory (Ducati, MV, some Yamahas, others I'm not sure of)....but have not listed for MV yet.
post #9 of 17 (permalink) Old 06-04-2009, 09:10 AM
wa2fst's Avatar
so you should then unplug your lambada sensor then?
wa2fst is offline
post #10 of 17 (permalink) Old 06-04-2009, 09:22 AM
Nope...won't work. ECU goes to fail safe mode.
