Hi Guys - a bit of help would be appreciated.
Took bike for quick, stop /start ride on Saturday - all fine. Got all dressed-up for long run Tuesday night....but bike now totally dead - no ignition sequence on dash - screen totally greyed-out - nada. Thinking battery was dead, got new one sent overnight - but exactly the same result....nothing !!
Any ideas ? I've checked all the fuses & even dug-out and read alarm/immobiliser instructions just in case it had kicked-in when I disconnected the old battery...
Any thoughts/similar experiences gratefully recieved.
Cheers.
Cheers.
Sponsored Links | |||
Advertisement |
Check the negative battery lead. Not on the battery, but where it is grounded. Double check it
John
And you tested the new battery you bought to be sure it was fully charged?
You installed the battery correctly? It is very easy to mix up the + and -. Happens all the time.
Welcome aboard!
Welcome aboard!
Yep...
Checked new battery & eventually got it in the right way...heven't checked grounding on
negative yet tho - thanks will try that.
Any other thoughts welcome - really bugging me & great weather - ARRGH !!
When you checked the fuses did you also check the recharge fuse found under the seat? It's separate to all the other fuses.
If that fuse goes your battery will run flat very quickly while the bike is running and the bike would indeed appear dead the next time you try start it. Happened to me - the bike went around the block then died completely. Replaced the fuse and got a new battery and problem was solved. Perhaps you have a similar issue.
Thanks - yes, tried that as well - what I think (according to the user manual) is the "live" fuse (on the left) is OK - but, what I think is the spare (on the right) has gone...so, my vain hope at the moment is that this might be it & off to fuse-shop first thing tomorrow....
I had exactly the same - also a few others, Taff4 etc.
It was a break in the wiring loom on the right hand side (as you sit on it) roughly by your right knee under the fairing, where the thick bundle of wires curves under the frame. The downward loop collects water and the stress of the curve allow corrosion (IMHO).
It was sorted very quickly by the local jap bike dealership.
Thanks Harvey - will def. check that one out - appreciate it. Fingers x'd !!
Did you charge the new battery?
B4 750S [sold]
B3 675R [waiting]
My Ducati has a master fuse (40 amp) beside the battery. Does MV have anything like this in the loom ?
01 750S W/1000R engine
01 Ducati 748 W/853 kit
03 Yamaha R1 (SOLD)
01 Kawasaki KX 125
88 Yamaha YSR 50
01 Yamaha R6
03 Suzuki DRZ pitbike
1982 Honda 110 atc
Yamaha PW50
1978 Honda 90 atc
2011 Yamaha Grizzly 700
2008 Yamaha Raptor 660
1975 Kawasaki G5 100
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
