MOT Test - safety related issues - MVAgusta.net
post #1 of 13 (permalink) Old 05-26-2009, 08:55 AM Thread Starter
Submariner's Avatar
People,
In the UK after a vehicle is 3 years old it is subject to a yearly "MOT" inspection which looks at things like lights, tyres, bearings, horn etc.
My 2000 model MV F4 is up for it's MOT in a week. It has done 4300 miles since new in 2000 and to date I have not noticed anything that doesn't feel right. It has a standard exhaust.
Can anyone advise on common MV faults which occur prior to or at around this mileage. I cannot feel any wear etc in the headset, the tyres are all OK and all lights are functioning properly.
I am slightly concerned that the wheel bearings might struggle at this mileage, although I have not felt anything that could suggest worn bearings (although I dont know if such a fault worn become apparent quickly)
Paul
Submariner is offline
post #2 of 13 (permalink) Old 05-26-2009, 11:49 AM
tt nick's Avatar
hi submariner
mine is a 2006 with 6500 on the clock no problems
passed first mot
so at your mileage dont think you will have a problem
cheers nick
tt nick is offline
post #3 of 13 (permalink) Old 05-26-2009, 12:01 PM
MV Mano's Avatar
Hi Submariner,
I brought my uncles Fazer 1000 to MOT last week and the guy walked round the bike and shrugged his shoulders and then said he would get me the certificate. Basically he gave the impression he didnt know what to look for. I have experienced this before on other occasions. If your bike is clean and your tyres are good condition then I dont think you will have a problem. Besides do you not need to have the paddock stand to check the bearings (I think this is the case)? Unless your MV has a centre stand I wouldnt worry lol. I bet it breezes through. Good luck.
MV Mano is offline
post #4 of 13 (permalink) Old 05-26-2009, 04:20 PM Thread Starter
Submariner's Avatar
Cheers fellas, I will make sure it is looking super duper so the scene is set when the MOTer first sets eyes on such a glorious motorcycle
post #5 of 13 (permalink) Old 05-26-2009, 05:06 PM
Banned
my 2003 EV03 has got through MOT's every year no problem with only 2 hick-ups, one was side wear on rear tyre, which was my own fault and I should have picked up on,
the other thing that was picked up was wear on the bush on my rear shock, it never failed for this but a cuationary notice was attached to the MOT, this was a thing I never considered looking at prior to the MOT
maybe worth a check
F41NXS is offline
post #6 of 13 (permalink) Old 05-26-2009, 05:39 PM
mikef4uk's Avatar
maybe worth a check
They all seem to have a little wear there, all 3 of mine had, I think it's probably the quality of the rose joints in the height adjuster
mikef4uk is offline
post #7 of 13 (permalink) Old 05-26-2009, 05:41 PM
Harvey's Avatar
The standard test for steering bearings is to tilt the bike over the stand so that the front wheel is raised slightly, then turn the steering, looking for a central 'notch'. Then push the front forks back and fore, looking for play. The wheel is then grasped top/bottom and wiggled, again looking for play in the wheel bearings - this will show up a loose wheel as well.
(I'm not an MOT tester, but I've seen a few who look as if they know what they are looking for).
Harvey is offline
post #8 of 13 (permalink) Old 05-26-2009, 05:56 PM
redtail's Avatar
Mine was MOT'd last week. 2002 with 11500 miles. passed no probs. There were two guys doing the test. One was balancing the bike on one wheel and side stand while the other checked the bearings, etc. Wasn't to happy as I've had a side stand snap.
redtail is offline
post #9 of 13 (permalink) Old 05-28-2009, 08:27 AM
With an early F4 one thing that you might want to look at is whether your rear brake is still working correctly as they go off very quickly. I always bleed mine right before an MOT as 100 miles later it's non-operational again.
Si
TheCatWhisperer is offline
post #10 of 13 (permalink) Old 05-28-2009, 08:55 AM
X81
Is the correct answer, every single MV i have seen from brand new to 10 years old has free play in the rear end, it "feels" like a suspension bush that has gone but is actually the rose joints in the ride height adjuster.
If it is likely to fail on anything it will be that.
Otherwise check that brake pads are within limits, forks seals aren't blown, wheel bearings are not knocking, headraces aren't loose and knocking or tight and notchy.
HTH
X81 is offline
