Best exhaust upgrade for F4 312RR 1078?? - Page 2 - MVAgusta.net
post #11 of 17 (permalink) Old 05-24-2009, 05:26 PM
minime's Avatar
What's your budget for the exhaust system? Warranty would be a very grey area, technically any exhaust except the stock unit will not be warrantied because all after market exhaust including Rg3s are for race only use.
Removing the cat is a big no no in Australia.
minime is offline
post #12 of 17 (permalink) Old 05-24-2009, 05:43 PM
The_castle's Avatar
From an email by the man himself, Eraldo Ferracci:
You can't use the Power Commander with stock ECU and O2 sensor.
The only way to use the power commander is to replace the ECU Part F47802 Price $615.95 discard the O2 Sensor, run the bike should be ok, if still no the way you like, now you can purchase the Power commander it came with software so you can map. PC 730-411 price $349.00
Take Care and thank you for purchase our products.
To see the full story go here: http://www.mvagusta.net/forum/showthread.php?t=22849
Note this is for a 312R but if you are replacing any part of the stock exhaust system, particularly the catalytic converter or installing less restrictive pipes you should install the "race" ECU.
The_castle is offline
post #13 of 17 (permalink) Old 05-24-2009, 05:52 PM
MV-999R's Avatar
Dave, do you know if any PC3 for the F4's is good to install on the 312R (with "race" ECU and decatted mid pipe?) or do i need a specific PC3?
MV-999R is offline
post #14 of 17 (permalink) Old 05-24-2009, 07:06 PM
The_castle's Avatar
Hi Tiago,
The best information I have is that it should be PC 730-411. Just Google "power commander 730 411". There seems to be plenty of places to buy this item. I can tell you that the race ECU should work fine and not require a power commander, as Mr. Ferracci explains above, but I should clarify 3 things:
1. The race ECU comes with one of two fuel curves either Street for slip on exhausts only or Race for full systems (no catalytic converter and oxygen sensor removed and open exhausts eg: Bodis, Arrow, Moto Corse FBF etc). You should specify which ECU (Street or Race) best fits your current setup.
2. The standard ECU on the "euro 3" - (catalytic converter welded to headers) 312R is not compatable with any power commander.
3. Power Commander 730 411 is optional for further tuning of the fuel curve once the Street or Race ECU is installed. It is only required to fine tune fueling if the Street or Race ECU requires any adjustment along the rev range.
Hope that helps,
Dave.
post #15 of 17 (permalink) Old 05-24-2009, 07:39 PM
MV-999R's Avatar
Thanks Dave.
I already have the "race" ecu, but i have no idea if it has the street map or the race one. I do have the full system (arrow headers, no catalytic converter and oxygen sensor removed) along with RG3's.
My race ECU is from emoto, but i bought it from a forum member, not them
I may go the RapidBike route, since it can change the ignition timing and as far as i know that's the best way to eliminate the 5000rpm surge.
MV-999R is offline
post #16 of 17 (permalink) Old 05-24-2009, 10:09 PM Thread Starter
Cash_Dawg's Avatar
Thanks for all the info and opinions so far.
I've been hearing mixed reports of the RG3's and thanks to a forum member here who has a set nearby I might be able to check them out and hear them first hand.
I have done a little more research on the Moto Corse Ti/evoluzione system and putting price aside it seems to be a good way to go.
If I can get away with changing the slip-ons and possibly getting rid of the Mid-pipe and cat without having to change the ECU or adding a power commander, I think that might be the option.
Does anyone know of a supplier for the Moto Corse gear that has more info in English includin pricing?
Cash_Dawg is offline
post #17 of 17 (permalink) Old 05-25-2009, 10:43 AM Thread Starter
Cash_Dawg's Avatar
I haven't really set a budget for the exhaust yet. Just trying to get an idea of what would suit and be best. Then i'll look at working on the cash. Being the type of bike it is, I'm definitely not going to skimp on the price, and dont minding spending extra if its a quality product and worth the money.
You may post new threads
You may post replies
