Adjusting you PC III manually is really pretty easy. Follow these steps :
* Attatch your 9 volt power adapter to the PC III.
* Make sure the kill switch is in the run position and turn the ignition on.
* Within 5 seconds of turning on the ignition press all three buttons down simutaneously.
* Select the range you wish to adjust; Low, Med, High, by pushing the corresponding button once.
* At this point holding that button down will move the lights down (leaning the map).
* Pushing the button repeatedly will move the light up (richening the map).
* When the two center lights are lit up this is the "0" setting.
* After making your adjustments wait 15-20 seconds before starting or shutting off the bike. This allows the settings to be saved to memory.
* To verify that it is safe to start the bike or turn it off, move the throttle and watch to see if the lights ove up and down the scale. If they do, you may start or turn off the bike.
!!!!!!!!! If you do not have the power adapter, there are a different set of instructions. Do not attempt to adjust if the adapter is unavailable !!!!!!!!!!
Let me know what you need and I will post instructions for no adapter.
Cooper
01 750S W/1000R engine
01 Ducati 748 W/853 kit
03 Yamaha R1 (SOLD)
01 Kawasaki KX 125
88 Yamaha YSR 50
01 Yamaha R6
03 Suzuki DRZ pitbike
1982 Honda 110 atc
Yamaha PW50
1978 Honda 90 atc
2011 Yamaha Grizzly 700
2008 Yamaha Raptor 660
1975 Kawasaki G5 100
