GP shift and quickshift for F4 - MVAgusta.net
 3Likes
  • 2 Post By silentservice703
  • 2 Post By merc07
post #1 of 10 (permalink) Old 04-12-2018, 08:58 PM Thread Starter
richd748's Avatar
Looking for recommendations on new rearsets to convert to GP shift and quickshifter recommendation for my 2007 F41000R. Don't want reverse drum.
I found these Sato but seems to be excessive cams/gears required to accomplish this.
Current:
2014 Aprilia RSV4 R
2007 MV Agusta F41000R
Previous:
2004 Suzuki Boulevard M50
2001 Ducati 748
1991 Suzuki GSXR 1100
1988 Kawasaki EX500
richd748 is offline
post #2 of 10 (permalink) Old 04-13-2018, 07:29 AM
The key to making this system work well is to ensure the connecting linkages are as close to 90 degree angles as possible. This will transmit as much undiminished motion and energy as possible through the linkages.
post #3 of 10 (permalink) Old 04-13-2018, 07:44 AM Thread Starter
richd748's Avatar
Is there a rearset with direct connection to shifter arm?
Current:
2014 Aprilia RSV4 R
Previous:
2001 Ducati 748
1988 Kawasaki EX500
richd748 is offline
post #4 of 10 (permalink) Old 04-13-2018, 08:02 AM
The shift arm on your bike is directly connected to the shift drum.
In order to affect a reverse shift pattern, the shift lever would have to be flipped so that the motion is reversed. In order to do that (without the reverse drum), you need a linkage.
Gilles Tooling has rearsets that have minimal linkage that might be able to do just that.
On my 312R, were I to flip the lever (green bos) to the red position, the shift action would be reversed. I do not know if there is clearance to the sprocket cover,or other hard parts, for this.
Teeps and Teeps like this.
post #5 of 10 (permalink) Old 04-13-2018, 08:24 AM
dansoarr's Avatar
Theres a few out there, I use PP tuning for most of my bikes https://www.pptuning.eu/catalog/tuningove-dily/5330f
I don't think you need a complex linkage as the bodywork should be in clearance.
On my F4 I run standard and have reverse shift and no issues with clearance or maintaining geometry (albeit 2015). I was given some rearsets by a mate for the F4, I cant remember who made them but can check.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is online now
post #6 of 10 (permalink) Old 04-13-2018, 09:48 AM
Been doing this for the last ..... 8 years. There's a lot of options out there.
post #7 of 10 (permalink) Old 04-13-2018, 09:58 AM
@Donsy: Good to see you back.
post #8 of 10 (permalink) Old 04-13-2018, 09:17 PM Thread Starter
richd748's Avatar
Thanks, really like these, going to order a set.
Current:
2014 Aprilia RSV4 R
Previous:
2001 Ducati 748
1988 Kawasaki EX500
richd748 is offline
post #9 of 10 (permalink) Old 04-13-2018, 09:18 PM Thread Starter
richd748's Avatar
Any imput on recommended quick shifter
Current:
2014 Aprilia RSV4 R
Previous:
2001 Ducati 748
1988 Kawasaki EX500
richd748 is offline
post #10 of 10 (permalink) Old 04-14-2018, 02:59 AM
Have a look at the Cordona PQ8
Donsy and Donsy like this.
merc07 is offline
