2002 F4 750S cutting out - MVAgusta.net
  • 2 Post By silentservice703
post #1 of 7 (permalink) Old 12-27-2017, 04:04 PM Thread Starter
Hey all, I'm hoping to get some answers here.
Our 2002 F4 750 is cutting out. You'll be riding alng and it'll suddenly cut out, no misfire, no back fire, just dies. The revcounter sinks like a stone too, it doesn't stay with the engine rpm, then it'll suddenly kick back in the the rev counter will match engine rpm. Sometimes it'll stay on power, other times it'll just die again.
I've cleared the tank breathers, the fuel pump primes. No kinks in breathers or fuel lines, asnyone got any ideas?
Cheers,
Shane
KiwiMV750S is offline
post #2 of 7 (permalink) Old 12-28-2017, 09:31 AM
You have a loose electrical connection somewhere!! On a primary power lead or ground. Do the lights also go off when this happens? Latch relay failing maybe??
post #3 of 7 (permalink) Old 12-28-2017, 01:09 PM Thread Starter
Lights stay on, as does the speedo and temp guage.....getting frustrated now!!
Shane
post #4 of 7 (permalink) Old 12-28-2017, 01:23 PM
Time to delve into the wiring diagram and see what is common to your failure.
post #5 of 7 (permalink) Old 12-28-2017, 01:43 PM
bioluminescence's Avatar
If all the electronics stay on, but the engine turns off, its most likely the side stand switch.
When they go bad, they start the kill the motor on an increasingly frequent basis.
My 2003 F4 750 had 2 of these go bad over a 5 year period. good news is they're cheap....
https://www.ebay.com/itm/06-MV-Agust...9Y8AuJ&vxp=mtr
Nighthawk 650 '83 prune/gunk
FZR 600 '93 red/white
F4 750 '03 red/silver
F3 800 '16 ABS red/silver
bioluminescence is offline
post #6 of 7 (permalink) Old 12-28-2017, 03:01 PM
Unless something changed in 2002, I'd be looking at the clutch switch and the side stand switch and all of the ground connections.
post #7 of 7 (permalink) Old 12-28-2017, 09:16 PM Thread Starter
Bypassed the stand switch and clutch switch...still happening....plus it blew the 15a coil/injector fuse this time. I did find an injector with a damaged connector. New injector ordered.
Any more ideas?
Shane
