F4 Bar ends wont stay put
Hey everyone,
My bar ends, which I replaced to add a bit of weight and reduce vibration, won't stay put in the bars. I removed the screw and stock bar ends and replaced the bar ends with new ones. As I rode recently, the right screw kept sliding out. Fortunately the bar end didnt fall out too.
I have noticed that the long bar end screw goes thru the bar end and thence screws into a threaded rubber plug like thing. It appears (???) that the rubber plug like thing is supposed to (??) hold the entire works, by friction, inside the bar? It makes no sense to me.
I cant even explain it well other than to say when I pull gently on the bar end, the whole works comes out...bar end...screw...and rubber plug thing. What exactly is the bar end screw supposed to anchor to, other than the plug thing? Or is that it? And if so, how is the rubber plug thing supposed to anchor, other than by friction?
Completely baffled...help/comments appreciated.
Sponsored Links | |||
Advertisement |
You are exactly correct. The screw anchors to the rubber plug thing. Tightening the screw expands the rubber.
So, you have either not tightened the screw enough, the rubber is shot and the nut embedded in the rubber is backing out or the rubber plugs are too small for your clip ons and are not expanding enough.
Thanks CAG that helps.
I think that since the "whole works" comes out I have been trying to put them back in wrong. Perhaps I should put the rubber plug inside the bar FIRST, and sort of shove it in with a screwdriver or something, and THEN put the bar end in, and THEN insert the screw and tighten?
The rubber on the plugs looks just fine, and the internal thread part is very secure and not stripped.
Put the screw threw the bar end and attach the plug. Tighten the screw enough to compress the rubber plug, but not enough that you can't fit it in the clip on. Press the whole assembly in the clip on and tighten the screw. It should be fine.
couldn't type it fast enough. CAG is on point, per usual.
If your stock 'rubbers' are shot
, we have brass ones like the ones you find on the Ducatis that will work. Just let us know.
They look just like the ones we have with our universal barends. You will need the size B inserts and longer screws.
Motovation is now on Facebook -
Ball & Chain magnet
make sure you have the rubber plugs going the right way so that when the screw is tightend, it will expand...if you have the rubber plug on the wrong way, it will not expand (just figured I'd say this as it has happened to me
Also be sure the rubber and inside of the bar isn't oily...the rubber will just spin instead of expanding when you turn the screw.
Thanks all - I'll give the above a try this Sunday when I'm out at the 'roost.
On my F4 1000 the entire front end won't stay put................on the road , that is.
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
