06 f4 1000? - MVAgusta.net
post #1 of 26 (permalink) Old 09-03-2017, 06:29 PM Thread Starter
06 f4 1000?
i have my sights on a 06 F4 1000 with like 150 miles on it. i had an 06 brutale 910 and loved it except for the abrupt throttle. i could not come on the throttle smoothly to exit a corner. does the 06 F4 have the same issue and is there a cost effective fix for it? i was considering and looking for an 08 F4R 312. how is the throttle control on these?
dougn is offline
post #2 of 26 (permalink) Old 09-03-2017, 06:42 PM
R1andrew's Avatar
I had a 2007 1000R and it had the 5k rpm surge. So when you say 06 is it a 1000R? Depending on where you are in the world, us in the US got the bikes later. I installed the Race ECU and it got rid of most of it. Chuck knows a guy that can reflash the stock ECU for you.
R1andrew is online now
post #3 of 26 (permalink) Old 09-03-2017, 07:32 PM Thread Starter
im in the US (san jose)
dougn is offline
post #4 of 26 (permalink) Old 09-03-2017, 10:14 PM
MV Arthur's Avatar
My 312R is a lot smoother after I put in a Microtec.
2009 F4 RR 1078 312
2005 F4 Tamboweenie
2005 F4 1000S
1999 Aprilia RS50
1996 Ducati 916
MV Arthur is online now
post #5 of 26 (permalink) Old 09-04-2017, 07:45 AM
@dougn: There are a few threads on this issue. The 5SM ECU can be tuned to remove the dead spot dip that causes the abrupt throttle. The 1.6M ECu can also have a new chip (see Merc07) or have the current chip flashed.
If you want to pursue the reflash option, send me a PM and I'll put you in touch with the guy who can do it.
Chuck
post #6 of 26 (permalink) Old 09-04-2017, 11:11 AM Thread Starter
Chuck
thanks, which ECU does it have?
dougn is offline
post #7 of 26 (permalink) Old 09-04-2017, 06:02 PM
Question
Are you talking about a 1000S or 1000R ?
post #8 of 26 (permalink) Old 09-04-2017, 06:37 PM Thread Starter
a 1000S
dougn is offline
post #9 of 26 (permalink) Old 09-05-2017, 05:10 AM
It looks like the 1000S was a 1.6M and the 1000R started the 5SM.
You can tell by looking at the ECU. One long side electrical connector = 1.6M. Two top mounted electrical connectors = 5SM
post #10 of 26 (permalink) Old 09-05-2017, 09:45 AM Thread Starter
that means it has a removable EPROM (like an 06 brutale) right?
dougn is offline
