Mv Agusta F4 1000 2005 - MVAgusta.net
post #1 of 14 (permalink) Old 09-06-2016, 01:16 AM Thread Starter
Hi to all
I had a problem with my bike and asked for some advice and did some research...
So at the end it was the ECU
So i ordered a new one
My next question is :
( MY BIKE still has the old ECU )
Two weeks ago i had a problem with my bike cause it started to malfunction like something was wrong with the sparkplugs so i removed all of them and the problem was located in piston # 2
Piston order :
From left to right
( 1 ) ( 2 ) ( 3 ) ( 4 )
Sparkplug went black ( bad fuel burning i guess )
So i replaced the old ones with new laser iridium sparkplugs
Went for a ride and PUMMM there goes again with the same problem so i bought a new set of sparkplugs and replaced them all
Went for another ride and PUMMM same problem again
The question is :
IS THIS RELATED TO THE ECU
Erik Andrade is offline
post #2 of 14 (permalink) Old 09-06-2016, 02:19 AM
No, it's not your ECU, it's your EBS relay.
Look in the Maintenance section for 4-cylinder bikes please Erik, same place where you posted your previous thread about your ignition not working.
post #3 of 14 (permalink) Old 09-06-2016, 03:02 AM Thread Starter
Tks Donsy you are very kind ... we are very lucky to have you here
post #4 of 14 (permalink) Old 09-06-2016, 04:19 AM
Ok Erik.
I will move your thread to the Maintenance section, and then see if I can find some other threads on this very common fault from the F4 1000S bikes.
Do you know what I mean when I talk about the EBS relay, it's a little black relay on the l/h side of the engine, almost near the radiator. This little relay operates the valve which operates the Engine Braking System (EBS).
When this relay goes old and shitty, it's causes the bike to start running on 3 cylinders, like your bike is doing, people then relocate the relay to a cooler position, but also put some insulation around the relay to keep it from cooking.
post #5 of 14 (permalink) Old 09-06-2016, 05:35 AM
There is a brand new EBS relay in the Fore Sale section of the forum....
post #6 of 14 (permalink) Old 09-06-2016, 05:51 PM
Erik;
save your self a bunch of grief........and just get a chip from Adam (merc07)
no more EBS relay or solenoid
fans come on at 85C no more BS
real ignition and fuel maps
post #7 of 14 (permalink) Old 09-06-2016, 07:53 PM Thread Starter
Hi THEKNURL
Hiw can i get in touch with Adam
post #8 of 14 (permalink) Old 09-06-2016, 09:31 PM
Rudy2's Avatar
Watching I'd like to get one for my 06 also already replaced my Ebs once. Would be nice to have the fans come on early too.
Rudy2 is offline
post #9 of 14 (permalink) Old 09-07-2016, 05:38 AM
Hi THEKNURL
PM him:
http://www.mvagusta.net/forum/member.php?u=21379
post #10 of 14 (permalink) Old 09-09-2016, 02:38 AM Thread Starter
Is this the chip ?
