F4 LED H3 low beam globe - MVAgusta.net
LinkBack Thread Tools
Old 03-22-2016, 03:32 AM Thread Starter
vivere's Avatar
Lightbulb F4 LED H3 low beam globe
Has anybody tried using an LED H3 low beam lamp in their F4?
If so, any recommendations?
vivere is offline
Old 03-22-2016, 04:27 PM
Ryan Stewart's Avatar
Most of those JUST bulbs work poorly because they arent a single point of light so the reflectors dont hit it right. Its much better doing HID.
Ryan Stewart is offline
Old 03-24-2016, 10:36 PM
Draginknee's Avatar
I have looked into this quite a bit lately as I'm wanting to remove my HID (yes it's nice but all the hardware takes up space and is a pain when I take the bike apart). It seems as if they have come a long way and now are just as bright, if not more bright then HID... the problem is that they are just as large. The newer ones has some large heat syncs on the back side of the bulb, and the harness has a small box similar to an HID setup... so it's not very beneficial if you are comparing the two. Only thing is there is 0 clearance behind that rubber cover that covers the access hole to the bulb... and anything that sticks out more than normal, say a hest synced led bulb, will not let that cover go back on leaving it open all the time.
"When you cannot ride de bike, you are very quiet at home in de sofa." -Rossi
I'm Curtis...
Email:
Facebook:
For used MV parts, look up my ebay user ID; "cbmx101"
Draginknee is offline
Old 04-01-2016, 08:48 AM
The issue isnt brightness but the way our reflectors are engineered. The only way they get the brightness is to have a big panel of LEDs, not one singular point of light. Our housings are designed for all of the light to come out of that tiny little filament inside the halogen bulb. A matched HID bulb (if its good) replicates that by putting its little gas inner bulb in the same spot. That means the accurate cut-off is maintained and the light pattern isnt modified. Having anything but that singular point means you are putting out an odd light pattern and possibly even sending light above the road, blinding people.
The new ballasts are ridiculously small anymore anyway. I had no issue putting a DDMtuning slim ballast between my dash and the nose cone by building a small bracket and using the dash mounting nuts to hold it in place. Just get the slim 35w (I think, whichever is smaller) ballast and run it. You dont need the bigger, one, the smallest is still going to double your light.
Old 04-21-2016, 05:39 PM
eduardo's Avatar
Talking about bulbs, i have this question about what type of upgrade white bulb can replace the OEM high beam bulb (which it doesn t lit anything). Looks like its not easy (impossible according to this electrician i know.....) to find the same fitment. Would you know what type can i use?
Thank you for any info you could give me on this matter ( F4 1000R 2006)
eduardo is offline
Old 04-21-2016, 10:23 PM
MVAgusta.net Sponsor
mitchy's Avatar
If you don't want to go to HID,there are many high performance halogen globes on the market that are safe for polycarbonate lenses and don't use more power.I use Narva Plus 100 globes which are great.Phillips also make more powerful globes.You need a high "Lumin" (think that's how you spell it).Same wattage as original but high Lumin is the way to go.
Bike- F4 1078 312rr
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is offline
Old 04-22-2016, 05:19 AM
eduardo's Avatar
I did have HID, for the low beam, but worked fine until it started to go out sometimes. Tried a new bulb, then tried a new ballast, and was happening the same problem, and the electrician wasn t able to sorted out, so now he got me a nice H3 bulb to the low beam, but to the high beam bulb replacement he told me the fitting was different, and that he couldn t find a bulb that could match the socket...
Let me look for those refferences you gave me. Do you know the reference number/letter, those you mencioned?
Cheers, Mitchy
eduardo is offline
Old 04-22-2016, 05:26 AM
eduardo's Avatar
I just made a search, and Narva is found in Australia but in Europe must be Osram or Phillips the brands to look for. But i m still lost. Its not H3, H4 nor H7...so what is it...
eduardo is offline
Old 04-22-2016, 06:36 AM
mitchy's Avatar
Here is one-
Bike- F4 1078 312rr
Mobile-0423041326
mitchy is offline
Old 04-22-2016, 11:11 AM
eduardo's Avatar
It is H3 after all. Is it my impression, or the socket connective part is different from the usual one? I say this because the electrician was telling my mechanic that the connection was different from the usual one...are you surge i can use thos bulb for the high beam?
eduardo is offline
