Has anyone removed the forks on the F4? I need to replace my seals. I am very mechanically inclined but I do not want to get into something I shouldnt with no knowledge. I was told by a buddy the hardest part is removing the front wheel and making sure I loosen the end cap? because if it is to tight then they would have to find a way to hold the fork from turning. anyone mind taking a pic or giving me a heads up? and lastly on my list of wants and trying to not Sh*^T in the other hand to see what fills up first. Where can I download the maintenance manual for the 312.
unlock the forks caps (just break them loose)
place the bike on rear stand, then lift the front up by using the correct type stand, ie under the lower triple tree
remove the calipers and front wheel
remove the fairings, all of it as you'll need to remove the air tunnels to unbolt the lower clamp
remove the clip ons
unlock the bolts on the lower clamp (6 of them)
then unlock the top clamp while holding the fork leg and slide it down thru the triple trees
You can buy the Marzocchi parts in Cali 661-257-6630
They had a better deal then the dealer BS.
Thx
Related Threads
MV Agusta Forum
1M posts
55.7K members
Since 2005
