2001 F4 10k Going Between Gears - MVAgusta.net
post #1 of 6 (permalink) Old 08-18-2015, 10:50 AM Thread Starter
Hi All,
Im new to the forum and had the f4 around 6 months.
i have noticed a problem keep occurring with the gears.
When im giving the bike some real gas and really pushing her and going through the gears i full between the gears and have no drive and if i put my foot on the pedal you can feel the teeth grinding.
i literally have to roll to the side of the road to a complete stop and kick it back it into gear.
Any advice as to what i should be checking or changing?
savini101 is offline
post #2 of 6 (permalink) Old 08-18-2015, 07:53 PM
Wink ?
there is a problem with your gear selector
drain the oil and look for pieces on the magnet
then go to page G11 of the parts manual
look at items
35
29 & 30
good luck....tell us what you find
post #3 of 6 (permalink) Old 08-18-2015, 09:29 PM
Deano's Avatar
Ah, one of my favourite subjects! First of all what Noel said. Doesn't sound like the main selector spring or you'd be stuck between two gears which is a random choice the fucker makes when it breaks. I'd also check the small springs underneath the pawls and what they call the spring supports that act on the pawl for sticking:-
Items 23, 24,25
Deano
Deano is offline
post #4 of 6 (permalink) Old 08-19-2015, 07:15 AM Thread Starter
cheers guys,
ill crack on over the weekend and let you know how i get on.,
post #5 of 6 (permalink) Old 08-19-2015, 07:21 AM
Technique or clutch bleeding could be a simple solution.
On the technique side, make sure your shift lever is adjusted for you. It can be as simple as raising or lowering the lever or chaninging the foot peg location. If you can't get your foot properly under or over the lever, shifting will not engage accurately.
On the Clutch Bleeding side, if you have air or old fluid, the clutch will not disengage proerly and the shift will be inefficient and could hang up in neutral space.
Check the easy things first.
post #6 of 6 (permalink) Old 08-24-2015, 10:54 PM
Wink ?
try shifting without the clutch.......that will eliminate that
Deano;
23, 24 & 25 control the direction of shifting either up or down
35 returns the lever to center......you can do that with you toe (DON'T.......FIX IT)
29 & 30 center the drum so the pawls can get another bite at the drum
