engine temp sensor - MVAgusta.net
post #1 of 11 (permalink) Old 01-13-2008, 10:58 AM Thread Starter
lee
lee's Avatar
engine temp sensor
The temp sensor located in the engine next to the thermostat housing is the source of engine temp for the ECU. It is a variable resistance type and serves several purposes one of which is to tell the ECU when to operate the radiator fans. It can not be changed out for one with different characteristics or it will throw everything off.
The question is this. Can the ECU be programed to turn the fans on/off at a lower temp without affecting any of the other functions of the temp sender?
C'mon all you ECU geeks, gimme the skinny.
lee is offline
post #2 of 11 (permalink) Old 01-13-2008, 05:43 PM
Sig.Scuro's Avatar
That would be great, if there was a way to do it....... summer is coming!
Sig.Scuro is offline
post #3 of 11 (permalink) Old 01-13-2008, 06:04 PM
Banned
If it is a temprature variable resistance then you could install a small variable resister in series or parallel depending which way you would like to alter the setting, however I very much doubt it is a variable temprature resister, it is more likly to be a thermister, in which case, no you can't change it.
stephen wood is offline
post #4 of 11 (permalink) Old 01-13-2008, 08:50 PM
1fastf4's Avatar
My 2002 750 fans would come on at 204 degree's. That sensor has since gone bad and has been replaced. However the new sensor that has been installed kicks the fans on at 218 degree's. It seems that their are some differences in how they are made. My bike now over heats where as before, it never got over 220. I currently has two temp senors on order to see if I can get lucky to have one turn the fans on sooner.
1fastf4 is offline
post #5 of 11 (permalink) Old 01-13-2008, 10:25 PM Thread Starter
lee
lee's Avatar
I don't want to change the temp sensor. I want to reprogram the portion of the ECU that operates the fans so as to shift the on/off temp range lower in order to start the fans sooner and perhaps get a jump on the temp increase fans. Someone on here has got to be familiar enough with the ECU to know if you can change the parameters on individual circuts or not. Show yourself and give your wisdom.
lee is offline
post #6 of 11 (permalink) Old 01-14-2008, 04:21 PM
Sorry to hijack your thread, but the pics of the "beast" are amazing! You built that? You need to post those up here!
post #7 of 11 (permalink) Old 01-14-2008, 07:03 PM Thread Starter
lee
lee's Avatar
Cag,
Yes, I did. With a few exceptions everything you see was either modified or made from scratch. Some by machine, some by hand.
I'm not sure the interest is there to post it and to do so smacks of horn blowing. But I'm very pleased that you like it, given the work you do.
Lee
lee is offline
post #8 of 11 (permalink) Old 01-14-2008, 07:17 PM
I don't know about that. This is a pretty open minded bunch. Also, our brothers (and sisters) here do appreciate quality no matter what form.
How about it? You guys want to see pics of a bike Lee about hand built? No b.s., this is no hack job.
post #9 of 11 (permalink) Old 01-14-2008, 07:42 PM Thread Starter
lee
lee's Avatar
Oh for God's sake. You post them.
lee is offline
post #10 of 11 (permalink) Old 01-15-2008, 04:11 AM
Ozboy's Avatar
Thumbs up
... c'mon guys post the pics up ...
Thread officially highjacked!
07 F41000R
09 Blazing orange Speedtriple
07 CBR 600RR trackbike
Ozboy is offline
