Raising the Rev Limit on the F4-S - MVAgusta.net
post #1 of 23 (permalink) Old 11-28-2007, 04:47 PM Thread Starter
Turbo329's Avatar
Guys,
Is there a chip that can be put in the S to raise the rev limit?
Or should I call Ferracci.
2005 MV F4-1000S
Turbo329 is offline
post #2 of 23 (permalink) Old 11-28-2007, 06:15 PM
Allan Gibbs's Avatar
Shouldn't a PowerCommander be able to do that? Sorry, don't mean to answer your question with a question.
Allan Gibbs is offline
post #3 of 23 (permalink) Old 11-28-2007, 06:30 PM
Yeah Im sure it can be raised, but do you really want to do that and push your engine beyond what it was originally designed to do without changing valves and what not? If you're going to do that then you should be going ALL out and do your "do deligence" to make sure you dont break your toy, or even worse, break your body. All kinds of nasty stuff can happen if you push an engine beyond its tolerances while riding. OUCH!!!!
F4R312 is offline
post #4 of 23 (permalink) Old 11-28-2007, 06:48 PM
Hey, if it can't take 17,000 rpms then they shouldn't have put a 17,000 rpm tachometer. That's false advertising - like saying an F4 312R can do 312 kph.
post #5 of 23 (permalink) Old 11-28-2007, 06:53 PM
ASM
ASM's Avatar
Will you call the lawyer or should we wait for Stephen...
Ciao, Andreas
ASM is offline
post #6 of 23 (permalink) Old 11-28-2007, 07:03 PM
Dova80's Avatar
I say we wait for stephen..
Dova80 is offline
post #7 of 23 (permalink) Old 11-28-2007, 07:21 PM
here we go...
post #8 of 23 (permalink) Old 11-28-2007, 07:56 PM
For the records, I'd love to see a top speed test between some 312s, an F4R, and F4S to see what the variance between the three models tranlates to outright speed. Now back to the topic.
I checked Power Commander's site and they claim thier Ignition Module can increase the rev limits on certain bikes:
http://66.132.187.150/powercommander...on_module.aspx
post #9 of 23 (permalink) Old 11-28-2007, 08:02 PM
lizzardo's Avatar
The Powercommander for the F4S will not be able to raise the rev limit. You would need to replace the EPROM for that.
2008 MV Agusta F4 312 R
2002 Ducati ST4S
1998 Ducati 748
1994 Ducati 900SS
1980 Yamaha TZ250G
lizzardo is offline
post #10 of 23 (permalink) Old 11-28-2007, 08:19 PM
Again, youre surfing a BIG wave on a small board. Good Luck!
Let us know how it works out. Should be interesting at least.
F4R312 is offline
