'06 F4 Brembo radial MC upgrade - MVAgusta.net
post #1 of 11 (permalink) Old 10-03-2007, 11:19 AM Thread Starter
I swapped out the stock front brake MC for a radial Brembo 19x20 MC. What a huge improvement. Awesome power and feel. This is a relatively inexpensive upgrade to get the full benefit of the Nissin 6-piston calipers.
If you are interested in better braking, you need to check this set up out.
charliep is offline
post #2 of 11 (permalink) Old 10-03-2007, 11:49 AM
dumbcomputers's Avatar
Links and Pics please
Bike History:
'88 Ninja 250 > '92 GSXR-600 > '01 YZF-R1 > '06 Brutale + '07 Customized VTX-1300
dumbcomputers is offline
post #3 of 11 (permalink) Old 10-03-2007, 02:09 PM
suryad's Avatar
My knowledge of brakes is next to nothing but I believe the Senna could benefit from this as well yes?
suryad is offline
post #4 of 11 (permalink) Old 10-03-2007, 03:55 PM Thread Starter
http://www.hardracing.com/Brembo/BremboMC.htmI went with 19x20
I think it is a good upgrade over Nissin MC. You need to get the integrate brake switch fitting and a remote resevoiur and a mount for the resv.
charliep is offline
post #5 of 11 (permalink) Old 10-03-2007, 04:59 PM
postman_bat's Avatar
nice mod
i had an ap racing one fitted to my rc51/sp1 from the standard one and the feeling on that was unbelievable
1 finger braking on mountain twisties
i might go this route for the mv
changing disc and pads 1st seems a bit of a waste when this mod normally cures most problems 1st
just my 2p's worth
postman_bat is offline
post #6 of 11 (permalink) Old 10-03-2007, 06:39 PM
altoon's Avatar
What brake lines did you go with?
Alex
altoon is offline
post #7 of 11 (permalink) Old 10-03-2007, 07:19 PM Thread Starter
I did not need to change the brake lines. It works. You can also get a 90deg transition. The leads from the brake switch just clear the air runner.
I did need to remove the right clip on and releave a small amount of the webbing to get clearance for the Brembo mount. I also had to remove the locating pin in the switch housing to properly position. Slight rotation of the throttle twist grip to celar the resv. I made the mount by modifying a MC mount that I had from a Ducati 996.
charliep is offline
post #8 of 11 (permalink) Old 10-03-2007, 09:11 PM
Carman's Avatar
I believe the 2007 Senna's already have this upgrade, I know mine came with Brembo's
Carman
Senna 204/300
Carman is offline
post #9 of 11 (permalink) Old 10-03-2007, 09:13 PM
Carman's Avatar
My bad, thought you were talking the brakes no the MC's
Carman
Senna 204/300
Carman is offline
post #10 of 11 (permalink) Old 10-04-2007, 11:45 AM
altoon's Avatar
That's interesting.
I was looking at the fitment of the Brembo 19X20 on my bike with the OEM lines and didn't like what I saw. The Brembo MC has the exit on the bottom, whereas the OEM exit is to the side (parallel with the clipon). A 90-deg elbow would help a lot, but I'm not aware of an adapter.
My issue was that the OEM lines were under a lot of tension with the Brembo, and that was with the suspenion at rest. What concerned me was situations where the front end would come up, like a corner exit, or a wheelie. The the suspension would go to the fully extened position, but the brake lines wouldn't allow it!
Do you have some slack with your setup? Is there a nice loop in the brake lines so the suspenion can lengthen?
Just asking. Again, 'cuz I wasn't able to get my 19x20 on there with the OEM lines.
Thanks,
Alex
altoon is offline
