Baseline Dyno on the '13. Ouch... - Page 2 - MVAgusta.net
post #11 of 51 (permalink) Old 05-25-2014, 05:11 AM
Maser's Avatar
Originally Posted by MV-Moose View Post
Is 158bhp bad for "out of the crate"??
It is when MV is claiming 200HP at the crank. 158hp at the wheel is more like 170hp at the crank. This is the little HP game that MV and Ducati are playing in an attempt to match the BMW S1000RR's numbers.
Just my 2 cents.
Toronto, Canada
Maser is offline
post #12 of 51 (permalink) Old 05-25-2014, 07:14 AM
PTsalas's Avatar
Need to compare the BMW on the same dyno for a more accurate comparison.
PTsalas is offline
post #13 of 51 (permalink) Old 06-08-2014, 03:11 AM Thread Starter
No change in HP, but other issues
Had the Bodis installed (slip-on only) and ultimately found out that Dynojet was mistaken and the PCV does not work on the 2013 model. Apparently the plugs are completely different. So I need to wait to see who comes out with one.
Other problem is with a base dyno and with the Bodis, still stock fueling, there are some serious glitches in the power curve. Some of it can be smoothed with a good tune, but EDR also believes something else is going on with the electronics besides fueling. Take a look at the major ups and downs on the graph. Anybody else have a base Dyno done to their 2013 model year F4? I just want to make sure it is not just my bike and I ave a problem.
2013 F4.
jimi1114 is offline
post #14 of 51 (permalink) Old 06-08-2014, 04:01 AM
EDR again, seems to be popping up every time with bad MV Dyno work.
post #15 of 51 (permalink) Old 06-08-2014, 11:39 AM Thread Starter
Why do you say its bad MV Dyno work. What are they doing wrong?
2013 F4.
jimi1114 is offline
post #16 of 51 (permalink) Old 06-08-2014, 01:42 PM
Dahulk's Avatar
Send a message via Skype™ to Dahulk
Would be great if there were a comparison from another 2013 f4 dyno results.
Dahulk is offline
post #17 of 51 (permalink) Old 06-09-2014, 09:37 AM
2012 has the same motor no? I'm planning on doing a bone stock run on mine in the near future. If I do, obviously I'll share it here.
2012 F4R
Seismic is offline
post #18 of 51 (permalink) Old 06-09-2014, 08:25 PM
BSR-1's Avatar
For one thing, it'd be nice if they provided a proper graph. With the graph so short (rather than square, full page) it's harder to see the detail in the curve.
2018 Husky 701 Supermoto
2018 Aprilia Tuono 1100
BSR-1 is offline
post #19 of 51 (permalink) Old 06-09-2014, 11:40 PM
WFOF4Pilot's Avatar
2012 has the same motor but 2013 has:
1. Twin Mikuni injectors (as opposed to the single injector per cylinder on the 2012) and
2. ElDor ECU as opposed to the Magneti Marelli 7BM ECU .
Oddly enough the ElDor Dyno that Jim has posted up here shows the same Fueling issues as the (older) Marelli unit !?!
But, please do post your results! -Davis
WFOF4Pilot is offline
post #20 of 51 (permalink) Old 06-10-2014, 08:10 AM
Pretty sure all the '10+ F4s have two injectors per cylinder.
Si
TheCatWhisperer is offline
