2012 mv agusta f4r wont start - MVAgusta.net
post #1 of 15 (permalink) Old 12-16-2013, 07:30 PM Thread Starter
Hey guys I was installing a melotti tail tidy on my f4 and tried to test if the plate light would work. Turned the key and I can hear the bikes systems making noises however the dash does not come on no lights work and of course the bike wont start. Already threw the battery charger on there to fully charge still nothing. The closest dealer is 4 hours away really dont wanna take it there please tell me what i did wrong and how to fix it.
CAZCADE is offline
post #2 of 15 (permalink) Old 12-16-2013, 10:15 PM
Formerly - dagmvagusta
Blackout's Avatar
Sounds like you blew one of the starter fuses above the battery. It should be a 40amp fuse check that one. Also make sure you didn't splice into the wrong wire.
Sent from Motorcycle.com App
"In the middle of difficulty lies OPPORTUNITY!"
Blackout is offline
post #3 of 15 (permalink) Old 12-17-2013, 12:55 AM
Wink
you wired something wrong......a 40 Amp fuse takes about a dead short to ground with a heavy wire to blow
look at everything you connected to, something will show heat abuse
post #4 of 15 (permalink) Old 12-17-2013, 01:18 AM
There is also a small diode that can blow...not the same as the one for a reverse polarity situation...that can cause your problem....at least on older F4s. I'd have to dive into the wiring diagram for your bike to see.
post #5 of 15 (permalink) Old 12-17-2013, 09:00 AM Thread Starter
Ok guys I un did the wiring for the plate light, never messed with the blinker wiring (didnt want them) swapped the 40 amp fuse with the spare by the battery and still nothing. I really wish i knew enough about all this diode stuff but unfortunately im an idiot. I really have a feeling its something simple but dont know. Should i try swapping one of those 8 fuses on the gear side with the spares.
FML
CAZCADE is offline
post #6 of 15 (permalink) Old 12-17-2013, 09:18 AM
Did you remove the battery to do the work?
post #7 of 15 (permalink) Old 12-17-2013, 09:50 AM Thread Starter
No sir. I prolly should have but I didnt.
CAZCADE is offline
post #8 of 15 (permalink) Old 12-17-2013, 09:53 AM
MvF4RR's Avatar
go to the main fuses on the LEFT side check them you will find the first or second fuse blown this controls the dash try them then disconnect the rear tail light refit new fuse 10amp had same fault with my 2012RR
MvF4RR is offline
post #9 of 15 (permalink) Old 12-17-2013, 09:57 AM Thread Starter
When you say right side. Do you mean brake lever side? Do I need to take off fairing? Thanks.
CAZCADE is offline
post #10 of 15 (permalink) Old 12-17-2013, 09:59 AM
MvF4RR's Avatar
Sorry Ment Left Side Gear Side
MvF4RR is offline
