2012/13 F4 1000RR Theory - MVAgusta.net
post #1 of 45 (permalink) Old 05-06-2013, 04:21 PM Thread Starter
Banned
In 2012 I purchased a new F4 1000RR, it runs ok now but the exhausts are always very, very sooty at the back, the bike as been in and out of the garage several times but no fault can be found. I have a theory can any body add/help?
I believe the 2012 RR was made using only two piston rings so that 201bhp could be achieved.
Does any body know how many piston rings there are in the new 2013 F4 1000RR ? I,m thinking that the 2013 model has been made using three piston rings and thats why MV say its bhp is now only 196 and I have also noticed when I have seen pictures of the exhausts on the new 2013 bike they are always very clear.
If my theory is correct the 2012 model has sooty exhausts because its burning oil.
stephen wood is offline
post #2 of 45 (permalink) Old 05-06-2013, 06:45 PM
revhead1957's Avatar
Maybe to test that theory you would have to get a cylinder leak down test done and some time on the dyno with a gas analyser. A lab test of the oil might show something too.
How was the bike run in? One of our local guys swears modern bikes should be run in with mineral oil to get the rings to bed in properly. He reckons running synthetic too early causes the cylinders to get a glaze and then the rings don't do their job.
revhead1957 is offline
post #3 of 45 (permalink) Old 05-06-2013, 08:39 PM
Stephen,
How many miles on the 2012?
I ask because my 1199S burned oil all the way until 2000 miles.
0700 is offline
post #4 of 45 (permalink) Old 05-06-2013, 09:37 PM
Wink
MVs have Nikasil coated cylinders and honed chrome rings
my MV uses ZERO oil, my Aprilia RSVR has Nikasil coated cylinders and uses ZERO oil
my BMW R1150GS at 58,000mi sucks oil like a Hollywood starlet chasing free white lines on a mirror
at 10,000mi it used 3/4 quart in 250mi.....LA to San Diego and back
now its down to less than 3oz/250mi
it doesn't have honed rings OR smooth bores
Stephen;
put a lambda meter on it, guaranteed its fueling, not oil
post #5 of 45 (permalink) Old 05-07-2013, 04:45 AM
mikef4uk's Avatar
I read that the 2012 RR only had two rings on the piston, but can't remember where I read it? anyone else find this?
As Steve says oddly the 2013 RR is 5hp down on the dyno from the 2012 model.is this MV returning to a 3 ring set up after too many ''sooty'' back end of the bike complaints?
You could always get the bike on a 4 gas analyser or even a 3 gas analyser, that may show up high hydrocarbons on the over run suggesting oil is getting past the rings?
mikef4uk is offline
post #6 of 45 (permalink) Old 05-07-2013, 05:57 AM
george4337's Avatar
LOL...I love your one liners Noel
george4337 is offline
post #7 of 45 (permalink) Old 05-07-2013, 06:18 AM
hennessy's Avatar
U r probly close to the mark... I'm betting the sotty back end is oil and not fuel (like normal) for one very good reason.. My 2010 F4 runs very clean, rarely have to clean the tips.... Until u pull a wheelie, at which point the bike sucks oil into the airbox, and without fail on the next start up will blow a heap of smoke out the exhaust, it clears up after 30 seconds or so but on that ride the tail pipes will get very sooty.... Get home clean them off and on the next ride it wont happen
It only gets sooty when it sucks oil, and i should point out its only a very small amount, just need to set up a catch can on mine.... So i would assume your problem could also b oil related
hennessy is offline
post #8 of 45 (permalink) Old 05-07-2013, 06:33 AM
Post
MV Service bulletin says run oil at min level.
post #9 of 45 (permalink) Old 05-07-2013, 06:34 AM
Smile Y12 Rr
Looks like three rings to me.
post #10 of 45 (permalink) Old 05-07-2013, 07:40 AM
hennessy's Avatar
Donsy where is the service bulletin, and when was that posted? As my bike was just serviced and if anything was slightly over full
hennessy is offline
