F4R/RR Mirror issue - MVAgusta.net
  • 1 Post By Al-
post #1 of 3 (permalink) Old 09-20-2019, 07:48 AM Thread Starter
christosc's Avatar
F4R/RR Mirror issue
One of the screws which hold the mini fairing/flap on the mirror has become lose and has fallen inside the mirror. I guess that without it, the mini fairing/flap will brake off with only one screw holding it in place. Does anyone know how to get into the mirror to put the screw back on its place without damaging it? I can see that there is a single screw holding the mirror casings together and I guess, that it must be easy to do when it comes to replacing the light bulb.
Thanks,
C.
2012 F4 RR Corsacorta
1995 Kawasaki GPz500S
1998 Yamaha R1 (White) Sold
1999 Kawasaki ZX6R Sold
christosc is offline
post #2 of 3 (permalink) Old 09-20-2019, 08:19 AM
Al-
Al-'s Avatar
you'll need to pop the turn signal out, being very careful because the tabs holding it on are easily broken, and it can be very tight even after removing the fastener. No light bulbs in there, just LED.
christosc likes this.
2006 Brutale 910S
2012 F4 RR
2012 F4 RR
Al- is offline
post #3 of 3 (permalink) Old 10-03-2019, 06:23 AM Thread Starter
christosc's Avatar
I did this with success the other day, there is a small screw in the middle, after you take that off, then you need to pop the turn signal from one end only, need to be vary careful not to break it as Al said.
Thanks Al.
