2010+ F4 Grabby Clutch (possibly other models too) - MVAgusta.net
View Poll Results: Grabby Clutch
Clutch slips perfectly, can launch like the best 4 33.33%
Clutch engagement can be sudden and fast starts are not safe. 7 58.33%
Sometime ok sometimes bad. 1 8.33%
Voters: 12. You may not vote on this poll
post #1 of 15 (permalink) Old 07-29-2019, 07:32 AM Thread Starter
dansoarr's Avatar
Just a quick question, how many F4 owners have found the clutch grabby? i.e at traffic lights if you use some revs for a fast start, the clutch will suddenly stop slipping and engage promoting an unintentional lurch wheelie etc. Saw another F4 bite the dust today doing (attempting) a fast start. He's not an owner on here, but soon to be.
May be applicable to other models too
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is online now
post #2 of 15 (permalink) Old 07-29-2019, 05:06 PM
MarkF4RR's Avatar
Al Fagan mentioned this on 44 Teeth during the budget bike battle. He said a lot Ducati’s he raced had the same issue, he suggested around 2000 rpm and feed in the revs as you drop the clutch.
Otherwise it’s how you describe it.
2017 F4RR
Avio Grey/Black Carbon
EAS 2.0 Quick shifter/Auto Blipper
MarkF4RR is online now
post #3 of 15 (permalink) Old 07-29-2019, 05:29 PM Thread Starter
dansoarr's Avatar
How's yours?
I've made some mods and I think I have cured the issue, time will tell.
Idea around the poll was too see if there is a common cause.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
post #4 of 15 (permalink) Old 07-29-2019, 11:43 PM
MarkF4RR's Avatar
Mine is grabby. First time I tried to get a decent launch I almost launched it.
Doing as Fagan describes has helped.
How have you mitigated the issue.
2017 F4RR
post #5 of 15 (permalink) Old 07-30-2019, 12:57 PM Thread Starter
dansoarr's Avatar
I'll PM you and if the fix is the same for you, I'll post it up for others to see what I've done and feel better that it is a proper fix.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
post #6 of 15 (permalink) Old 08-09-2019, 10:45 AM
christosc's Avatar
Hi Arron,
I do have this problem, but only before the engine (and clutch) are properly warmed up. It is fine after that.
Does yours do this even after your system has reached its normal operating temperatures?
C.
2012 F4 RR Corsacorta
1995 Kawasaki GPz500S
1998 Yamaha R1 (White) Sold
1999 Kawasaki ZX6R Sold
christosc is offline
post #7 of 15 (permalink) Old 08-14-2019, 03:02 PM
stephen3141593's Avatar
To fix the clutch you must replace the stock clutch. Replace it with an STM clutch and you will get smooth engagement. I put the STM clutch on my 2013 F4 and it's great. The clutch cost around $1000.
An additional improvement is to get a 30 or 31 mm diameter clutch slave to give more lever travel and increase the ability to modulate the clutch.
stephen3141593 is offline
post #8 of 15 (permalink) Old 08-14-2019, 03:16 PM Thread Starter
dansoarr's Avatar
Yes these are well know replacements, the question here is can we fix the clutch that came with the bike, not replace the clutch assembly with another design.
I have the EVR slipper clutch, but trying to prove a fix for the standard bike. Part of it is an engineering.challenge but also as a matter of principle having to spend beat part of 2k correcting poor designs on the MV is rather an irritation. Between the clutch and cush drive the F4 is let down.
The fix looks good, 2 bikes with same fix, I have another F4 to look at in September and one more that's going to get there's checked to.
Hopefully therefore we have a fix, and I'll document, post it up and then there no need to spend over 1k on replacement parts, unless you want too of course.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
post #9 of 15 (permalink) Old 08-14-2019, 03:19 PM Thread Starter
dansoarr's Avatar
Originally Posted by christosc View Post
Hi Arron,
C.
Mine was like it all the time, regardless of the temperature. Do you fancy taking a look at your clutch? It might be the same issue, just a different degree of effect.
I'm down in Ross-on-Wye, I'm often in Langley / Uxbridge if you want a hand, I can bring parts to try to fix too.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
post #10 of 15 (permalink) Old 08-14-2019, 03:30 PM
Chris J on this forum lives in Ross-on-Wye.....small world
