Chris from X-bikes NEED HELP - Page 6 - MVAgusta.net
 26Likes
post #51 of 72 (permalink) Old 07-31-2019, 01:02 PM
christosc's Avatar
The only obvious thing that is different in terms of functionality on the Microtec is that you don't need to pull the clutch in in order to start the engine.
This is for all my anorak friends.
C.
2012 F4 RR Corsacorta
1995 Kawasaki GPz500S
1998 Yamaha R1 (White) Sold
1999 Kawasaki ZX6R Sold
christosc is offline
post #52 of 72 (permalink) Old 07-31-2019, 01:59 PM
Originally Posted by hb88xx View Post
why not? it is just a switch between wires pin 5, which can be flipped when running. Loading maps into ecu is a different issue
Had not seen the pin-out chart before..... so there you have it. Just need another switch and wire into the comm cable connector.
post #53 of 72 (permalink) Old 07-31-2019, 02:08 PM
Soooo....DucShop here in Marietta GA is the US distributor !!! Good to know. Think I will go chat with Mark.
post #54 of 72 (permalink) Old 07-31-2019, 04:59 PM
Deano's Avatar
Like Ed, I'm old school. Once I have a map that works well why do I need to change it? Modern electronics are great but I'm a mechanical man and not electronically inclined. What point on my 1078 anyway, there is no traction control etc. to soften a map for rain, sport etc.? Running as good as I can get it only requires one map and I have a map I'm happy with for both exhausts I run.
Deano
esq'z me likes this.
2009 1078RR Brutale
Deano is offline
post #55 of 72 (permalink) Old 07-31-2019, 06:06 PM
For me it would be a case of one for road and one for full race pipes, to save having to switch ecuís or upload a different map to get the best out of each. Itís not at all necessary, but if the functions there I think Iíd be inclined to make the most of it
Nito
Nito is offline
post #56 of 72 (permalink) Old 08-01-2019, 11:35 AM
hb88xx's Avatar
Originally Posted by Nito View Post
Awesome info, thank you Is the Aux CN6 connector the same connector used to upload maps (the block in between the two main loom connectors (V and E)? Does pin 5 purely hook up to a switch which then goes to ground to activate map switch?
Thanks again
Nito
Yes it is
Nito likes this.
4,5Mg~3Al~2Ti~Fe
hb88xx is offline
post #57 of 72 (permalink) Old 08-01-2019, 11:37 AM
hb88xx's Avatar
Deano
That you decide not needing it is something different than telling the functionality is not there.
4,5Mg~3Al~2Ti~Fe
hb88xx is offline
post #58 of 72 (permalink) Old 08-01-2019, 04:22 PM
Deano's Avatar
I said I was not aware that it was possible. You are obviously more tech savvy than me. Also in all the software and manuals that came with mine nowhere does it mention how to adapt it to change maps on the fly let alone anything about what pin in a five pin plug does. Maybe I missed something but it didn't seem to mentioin this functionality anywhere.
Deano
2009 1078RR Brutale
Deano is offline
post #59 of 72 (permalink) Old 08-01-2019, 11:01 PM Thread Starter
Roehr@1250sc's Avatar
Well Motorcycle Mall is now sending the Micro tec ECU back to Chris to remap . BUT the Map on the ECU is Chrises as he is sent it pre loaded . Eurosports only installed it and gave to me but they had the same problem Motorcycle mall did and that is the bike stopped running . SO ,looks like the ECU was bad from New . Now we will have to see if Micro tec backs there product.
falcn likes this.
post #60 of 72 (permalink) Old 08-10-2019, 04:14 PM Thread Starter
Chris motorcycle mall and I have been emailing you please check email and respond thank you .
