F4 Gen 2 chaging rear tyre profile and TC recab - MVAgusta.net
post #1 of 12 (permalink) Old 10-26-2018, 11:04 AM Thread Starter
Spud's Avatar
On the F4 gen 2
Is there a function on the gen 2 dash to recalibrate the TC if you change tyre profile from say a 200/55 to a 200/60 ??
The Panni and RSV4 allow you to put it into recab mode and ride for a short distance to calibrate the TC on the new tyre circumference.
[SIGPIC][/SIGPIC]
Spud is offline
post #2 of 12 (permalink) Old 10-27-2018, 09:43 PM
Not that I'm aware of
stickmandj is offline
The Following User Says Thank You to stickmandj For This Useful Post:
post #3 of 12 (permalink) Old 10-28-2018, 07:17 AM Thread Starter
Spud's Avatar
Cheers fella.. with Chris from x-bikes ECU - is that intergrated into the IMU etc to allow this option ??
[SIGPIC][/SIGPIC]
Spud is offline
post #4 of 12 (permalink) Old 10-28-2018, 06:55 PM
I honestly can't say. I have a 2016 F4rr and have not seen anything in the menus that would suggest I can re-calibrate the traction control. Maybe the dealer can and possibly through some aftermarket solution but I haven't seen it on the stock bike.
post #5 of 12 (permalink) Old 10-29-2018, 12:38 PM
christosc's Avatar
You need a pre 2012 F4 in order to install X-Bikes' ECU (It is called Microtec 227). I have installed it on mine but I have not seen a re-calibration function on it. I need to take a closer look when I connect it to the laptop to see if there is anything that can be done in the user interface (which is richer in content than the dash controls) to rectify that.
So you think that because of the different profile, the tyre will spin at a different speed when leaning over and that the TC system needs to adjust to that new speed?
Interesting! I have fitted a 200 slick on mine (for track use), but didn't think of that!
When I am next with the bike I will connect the dongle to the ECU and have a look. I hope Chris from X-Bikes can give us an answer.
2012 F4 RR Corsacorta
1995 Kawasaki GPz500S
1998 Yamaha R1 (White) Sold
1999 Kawasaki ZX6R Sold
christosc is offline
post #6 of 12 (permalink) Old 10-29-2018, 01:57 PM Thread Starter
Spud's Avatar
Yep i had a motec on my 2008 312R which just controllesd the FR and IGN mapping plus launch control/QS etc
I had to add Gripone TC for traction control etc and this had a function for putting in the wheel circumference as going from a 200/55 to a 200/60 increases the circumference and the TC has to know about that to be able to calcalate proper wheel speed and slip etc
Without that feature then the TC is linked to std profile 200/55
[SIGPIC][/SIGPIC]
Spud is offline
post #7 of 12 (permalink) Old 10-29-2018, 02:33 PM
dansoarr's Avatar
To my knowledge there is no recalibration available on the eldor ecu's. To change the TC you will need to flash the ECU with after market software that allows manual adaptation such as ecustudio.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is online now
post #8 of 12 (permalink) Old 10-29-2018, 04:14 PM
Al-
Al-'s Avatar
The microtec and OEM TC setup on the 2012 and older bikes is based on a rate of change during acceleration based on RPM and gear (real or calculated). It won't care what size rear tire you use as it is not referencing the front wheel speed related to the rear wheel speed for the TC setting calibration. If you have a bike that that front and rear wheel speed sensors, then this does not apply. The difference between a 200/55 and 200/60 is less than 3% circumference, and the old style TC is pretty crude. It works, but it is crude.
Al- is offline
post #9 of 12 (permalink) Old 10-30-2018, 05:00 AM Thread Starter
Spud's Avatar
Cheers fella
I'm looking at a F4 RC 2017 so would expect proper TC with front/rear wheel sensor rings - but how can you change this, i know it can be done with different size rings, but would have expected to be able to change via ECU/IMU or Dash..
55 = 25.66 inch dia, 83.616 in circ 651.764mm
60 = 26.44 inch dia, 83.092 in circ 671.576mm
What does ecustudio allow you to do ??
update - just spoken to ECU Studio and they confirmed they have no control over the TC as its controlled by the IMU/ABS systems
[SIGPIC][/SIGPIC]
Spud is offline
post #10 of 12 (permalink) Old 10-30-2018, 08:10 AM
christosc's Avatar
Personally, I don't think you need to worry too much about 3% difference! When you are using the 3% part of the tyre (max lean) you shouldn't be on the gas anyway (unless you like to test the TC and do not care if it fails and you break your back), and things get more even as the lean decreases.
That's the simplest and more realistic approach on the subject. If you are interested in the science of it however, then please share with us your findings!
@ Al, the different tyre profile, would generate a faster/slower rate of acceleration when the tyre is using its leaned profile, so the pre-programmed (default) setting could "think" that the tyre has exceeded it's expected acceleration rate and would kick in earlier (or not kick in at this value if a larger profile is used). So what Spud is talking about applies to the 2012 or earlier models in my opinion.
