What r these connectors for?? - MVAgusta.net
post #1 of 15 (permalink) Old 08-12-2018, 01:32 AM Thread Starter
Majmv's Avatar
Under the rider seat I got 3 connectors. I think the one with the cap(green) is probably to connect a computer but are the other two for??
Majmv is offline
post #2 of 15 (permalink) Old 08-12-2018, 01:56 AM
cruiser's Avatar
red is battery tender -obviously needs the connector
Tim
Current
MV Agusta Brutale 1090RR
Past
MV Agusta Brutale 750s
cruiser is offline
post #3 of 15 (permalink) Old 08-12-2018, 05:15 AM
dansoarr's Avatar
Different location to mine but the orange is for diagnostics and flashing the ecu
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is offline
post #4 of 15 (permalink) Old 08-12-2018, 06:05 AM
revhead1957's Avatar
While you are under there, it might pay to peel black the black tape over wires leading to the 4 pin plug. It looks like it is getting hot.
This is a well known trouble spot. As the female connectors loosen there is a heat buildup which can melt the insulation, which then leads to a short circuit. The smaller wires at the back feed the ecu.
revhead1957 is offline
post #5 of 15 (permalink) Old 08-12-2018, 10:36 AM Thread Starter
Majmv's Avatar
By 4 pin u mean the started solenoid connector??
Majmv is offline
post #6 of 15 (permalink) Old 08-14-2018, 03:01 AM
Chilblane's Avatar
Hi, I am just about ready to buy the ECU Studio software and in preparation have looked under the seat and cowl for the diagnostics connection but to no avail. As we have similar age of bike whereabouts is yours located? Many thanks
2016 F4 RR mapped with ECU Studio
2017 Aprilia Tuono Factory
2019 F4 RC
Chilblane is offline
post #7 of 15 (permalink) Old 08-14-2018, 08:15 AM Thread Starter
Majmv's Avatar
I thought orange is for the battery tender. Green ( it has a cap) might be for the software n Ecu. It still leaves with yellow
Majmv is offline
post #8 of 15 (permalink) Old 08-14-2018, 08:17 AM
You are correct Majid...
post #9 of 15 (permalink) Old 08-14-2018, 08:21 AM
According to the shop manual for the 2010 F4, there is an additional CAN socket that is 4-pin.
post #10 of 15 (permalink) Old 08-14-2018, 11:17 AM
Chilblane's Avatar
Thanks guys, underneath the frame I found a capped 4 pin plug that looks (with capped removed) identical to the plug circled in yellow. I imagine this must be for access to the ECU
2019 F4 RC
