18' F4RR cutting out - MVAgusta.net
post #1 of 5 (permalink) Old 07-28-2018, 05:52 PM Thread Starter
So just had first service done yesterday. Went out today and had 5 different cutoffs at different speeds, most of them when coming to a stop.
Had the "malfunction" warning three times then "Fault SCU" twice. 2 times no malfunction or warning indicators at all. Recycled the key each time and bike continued.
After the first one I turned for home, and these all happened on the way.
Needless to say I am a bit disappointed. From reading earlier threads it seems the quickshifter could be a possible culprit but I dont see how a SCU fault could cut power to the engine.
I did get it home ok, and calling the dealer on Tuesday.
Any guesses?
Can anyone tell me if I am able to see the fault codes through the display somehow?
18' F4RR local
18' ZX-14 longer local
16' S1000XR touring
02' XR400
06' CRF450X
02' CBR1100xx sold
16' Hypermotard sold
17' Panigale S traded for MV
Flatulence is offline
post #2 of 5 (permalink) Old 07-29-2018, 06:18 AM
You have to get the bike in dealer mode to see the fault codes. I believe that is done through the diagnostic computer.
post #3 of 5 (permalink) Old 07-29-2018, 01:00 PM
dansoarr's Avatar
You need the dealer tool, most flash tools will also do it (that's what I use).
From what I have seen MV does not store the errors I'f the error goes away, intermittent or power cycle they just disappear. Causes fault diagnosis to be a pain.
If you have just had the service, back to dealer I'm afraid.
If you were coming to a stop, it should not be the qs. I'd turn it off in the dash and test again.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is online now
post #4 of 5 (permalink) Old 07-29-2018, 03:36 PM
OBD-2 Compliance requires Detected Trouble Codes be stored. Even after they go off on the dash they can be retrieved by the dealer diagnostic tool.
post #5 of 5 (permalink) Old 07-30-2018, 03:34 PM
dansoarr's Avatar
That's true for existing faults. If the system has X cycles where the fault has not presented it self then it can be self cleared by the ECU. Each manufacturer determines these faults and number of cycles before clearing the error, except emission errors if I recall.
From what I have seen on the F4, it's minimal storage for example, a dodgy gear sensor position indicator will flash upon the dash. You change geer or the fault disappears, there is no log in the ECU that MV can read. It's very fault dependant.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
