Handlebar angle adjustment - MVAgusta.net
  • 2 Post By flyboyk
post #1 of 3 (permalink) Old 11-12-2017, 07:46 PM Thread Starter
aprilia_rs250's Avatar
Hi all, do you know if the angle of the handlebars is adjustable on a 2015 F4?
I find they are a bit too swept back given my size (i am 6'3"). I would like them to be a few degrees more out, wrists feels like they are bending too much outwards.
I can't see anything in the manual in terms of adjustment like you can for clutch and foot brake pegs.
thanks
aprilia_rs250 is offline
post #2 of 3 (permalink) Old 11-15-2017, 05:40 PM
flyboyk's Avatar
There is a split pin that locates the clipons in a set position. You can cut that pin off and you will be able to adjust the bars. But not much, like at the most an inch before the clutch and brake fluid reservoirs start hitting the fairing . It`s hardly worth doing.
christosc and christosc like this.
2014 MV Agusta F4
Moto Guzzi 1100 Sporti
Yamaha R1
Honda CT90
flyboyk is offline
post #3 of 3 (permalink) Old 11-16-2017, 03:23 AM
Stradas's Avatar
I put bar-risers on mine but needed to change the fluid reservoirs to remote mounted ones.
It's a bit of effort but helped me a lot as I do quite a lot of miles and occasionally go touring.
Stradas is offline
