I got a hold on the previous owner of the bike,
He has had a lot of small problems
Rear brake not working, Water inside dashboard, warped disc, dead batterys , lost screws on kickstand and fairings, exhaust valve malfunction,
He has a full documentation in Swedish (
http://junk.hangout.se/mv.txt)
Problems he had:
Åtgärder:
* 2015-03-26 Luftning av bromsar (Bleeding of the brakes) - normal maintenance
* 2015-04-08 Byte av Batteri (Replaced Battery) - standard battery isn't great specially if you stop during the winter most have changed with a better option
* 2015-04-14 Luftning av bromsarder bak, Sulas MC (Bleeding of rear brake) - normal maintenance
* 2015-04-20 Byte av Batteri (Replaced Battery) - He replaced twice the battery?
* 2015-07-06 Byte av bromscylinder - Bakbroms går fortfarande inte att låsa, men "det är ofta så på ABS-hojar". (Replaced rear brake cylinder) - Probably following the rear brake not ok, but normally it's because of the position/heat.
* 2015-07-26 Skruva fast stöd och ersätta bultar. (Lost screws in kickstand and body) - First thing to check on the bike maintenance!
* 2015-08-04 Byte av bromsskiva fram (replaced warped front disc) - I've heard issues specially on the Turismo Veloce. Mine did some noise while stopping changed to EBC and irs perfect. SBS I had in stock also made some noise.
* 2015-08-04 Byte av instrumentpanel. (Replaced dash board) - I've never heard on the 2013 > F4
* 2016-03-12 Tar ut MCn för första gången efter vintern, har ingen bakbroms igen. (First ride of the seasson, Rear brake not working) - Already explained above
* 2016-03-12 Avgasspjäll trasigt. (Exahust valve broken and fully open, Previous owner fixed the by tightning wires as MV did not want to take it under warranty) - the exhaust valve error is a common issue around just check the forum many resolved this issue different ways: installed heal tech servo eliminator, removed the cables,...
So what do you guys make of this information?
