Datatool as standard - MVAgusta.net
 2Likes
  • 2 Post By george4337
  • 2 Post By fingertight
post #1 of 4 (permalink) Old 02-17-2017, 01:23 PM Thread Starter
Baggo's Avatar
Hello all.
Having just got hold of my bike and not planning on riding her while there is salt still present on the road, all I can do is tinker with her in the garage. While doing so, I have come across a Datatool S4 Red fitted under the seat cowling. Is this fitted as standard as I was surprised to find it as have no fob or even advised it was fitted. It starts no problem so must be disconnected somewhere but the wiring to it is taped up into the loom so wouldn't know where to start looking for the cut wires apart from near the unit, there is a double black wire which has been looped over to complete a connection maybe?
Any help appreciated as seems a shame to have one on the bike and not be used. Have spoke to Datatool themselves and they are saying, 'go to an approved fitting centre' which is not surprising, but was just trying to see if I could order a fob for this particular alarm.
Many thanks in advance
Baggo is offline
post #2 of 4 (permalink) Old 02-17-2017, 06:29 PM
george4337's Avatar
Probably disconnected for a reason.
Numerous threads on here about alarms causing issues
Baggo and Baggo like this.
george4337 is offline
post #3 of 4 (permalink) Old 02-22-2017, 10:12 AM
If you want/need an alarm type system I would suggest a tracker. Plenty of good ones out there to choose from as long as you don't buy a cheap one. They're battery operated that will last for months or you can hook some of them to constant power (doesn't seem to be recommended on an MV). You can set them so that if someone just bumps your bike you get a text immediately. And if they do manage to make off with it, you will find them and the bike.
2014 F4 RR
2008 Yamaha Raider S
1982 Suzuki GS850L
fingertight is offline
post #4 of 4 (permalink) Old 02-27-2017, 11:55 AM Thread Starter
Baggo's Avatar
Thanks for the advice, I hadn't read about the issues people were having with alarms on this particular bike, but have heard about them on others. Just a shame that it seems to be wired up into the loom and not able to use!
Baggo is offline
