2013 f4RR or 2012 f4RR? - MVAgusta.net
post #1 of 18 (permalink) Old 09-06-2016, 12:23 PM Thread Starter
hi im looking a replacement for my 848, i saw this gorgeous '12 and '13 F4RR. For '12 3000miles for $15,300 and for '13 8675miles for $16k. which do you think is better and anything i should know or do before i purchase it?? thanks....
skitz0 is offline
post #2 of 18 (permalink) Old 09-06-2016, 01:12 PM
2013. quick switching. electronic suspension module ecu upgrade program. abs
ildar is offline
post #3 of 18 (permalink) Old 09-06-2016, 02:28 PM
ARAMIS's Avatar
If the color is the same that you lik I would go for the 2013. I also have one and is a fantastic bike
ARAMIS is offline
post #4 of 18 (permalink) Old 09-06-2016, 02:56 PM Thread Starter
any issue on '13 i should worry about? i really like mv but the problem is the nearest dealer here is like 200 miles away. thanks
skitz0 is offline
post #5 of 18 (permalink) Old 09-06-2016, 03:19 PM
Al-
Al-'s Avatar
2012 because I'm a retrogrouch and don't like the idea of electronic throttle bodies
Al- is offline
The Following User Says Thank You to Al- For This Useful Post:
post #6 of 18 (permalink) Old 09-06-2016, 03:22 PM
midget81's Avatar
+1
Terry
2011 F4
midget81 is offline
post #7 of 18 (permalink) Old 09-06-2016, 07:48 PM
Fragile's Avatar
My 14 is fabulous, although I don't know why my brake discs warped so soon at 8K miles, but it is now confirmed so. I guess just because it says Brembo doesn't mean it won't have issues.
'15 Panigale R (2K miles)
'15 Fireblade SP (1K miles)
Los Angeles North
Fragile is offline
post #8 of 18 (permalink) Old 09-07-2016, 11:53 AM
Camberdually's Avatar
I went through a similar decision with 2012 f4R and 2013 f4. I ended up going with the 13 strictly because of color. if you are really going to customize it I would go with the 12 if you are going to slap some bolt ons and enjoy it fairly stock go with the 13.
Kevin
2013 F4 red/silver
Camberdually is offline
post #9 of 18 (permalink) Old 09-07-2016, 04:13 PM Thread Starter
Thanks guys!!!
skitz0 is offline
post #10 of 18 (permalink) Old 09-09-2016, 04:14 PM
Dahulk's Avatar
Send a message via Skype™ to Dahulk
I would add that 2012 was the last year before they went to fly by wire throttle and also change to eldor ECU. I have a 2012 F4RR and my friend had a 2013 F4. A few subtitle differences I have notice
- Almost no tension on 2013 F4 throttle compared to 2012 F4RR which I did not like
- Issues with sensor light for exhaust valve till he removed the whole assembly
- With the change of ECU the only option for a tuner was the rapid bike which was more expensive than the power commander.
- 2013 F4 had the quickshifter which I wish the 2012 had but I will add myself
- 2012 have the reqular Olins and not the adjustable electronics Olins shocks
- There seem to be more fuel map updates for 2013 Eldor ECU than 2012.
- I prefer the 2012 Colour Scheme better personally but that is my personal choice.
Hopefully my inputs help, either bike you choose I am sure you will be happy owning an MV. For me the 2012 I was able to map and fix some of the fueling issues cheaper than the 2013 fueling issues my friend experience. Not sure if fueling is still an issue as this was about a year ago.
Dahulk is offline
