2013 f4 no start - MVAgusta.net
post #1 of 8 (permalink) Old 09-21-2015, 10:16 PM Thread Starter
slomo's Avatar
2013 f4 no start
My f4rr was in the rain I know horrible but after work it was hydrauliced from the water not sure where it got in but also runs rough after washing it any ideas are there seals to look for near the throttle bodies that may be out of place thanks
slomo is offline
post #2 of 8 (permalink) Old 09-22-2015, 01:45 AM
Stradas's Avatar
Do you mean it was left outside in the rain and when you got on it to ride home it wouldn't turn over?
How do you know it was/is 'hydrauliced' - have you taken the plugs out and turned it over?
I can't figure out where rain water would get into the engine.
Stradas is offline
post #3 of 8 (permalink) Old 09-22-2015, 07:05 AM
Unless you have thrown it into a lake it is highly unlikley that there is water in the combustion chambers.
Try checking your electrics
Hawk is offline
post #4 of 8 (permalink) Old 09-22-2015, 11:18 AM
Water will cause issues with grounds. Water got inside my wire harness on my Honda and caused wires to corrode. If it is a one time issue water is definitely messing with a ground wire or similar.
steveh1209 is offline
post #5 of 8 (permalink) Old 09-22-2015, 11:55 AM Thread Starter
slomo's Avatar
well I stuck it in 6th gear and rocked it and put back into neutral and it started the second time was after washing and it was running on 3 for a second so looks like I have to remove the tank and investigate
slomo is offline
post #6 of 8 (permalink) Old 09-22-2015, 12:00 PM Thread Starter
slomo's Avatar
im thinking through the throttle bodies is where its getting in but like I said I haven't remove the tank to confirm
slomo is offline
post #7 of 8 (permalink) Old 09-22-2015, 07:15 PM Thread Starter
slomo's Avatar
Mystery solved air box seal out of place when water would pour down the seal acted like a deflector and allowed water to pool in #1 throttle body, should have looked when I bought the bike a month ago and broke my own rule of inspection before riding but was too pumped up to finally get a newer bike , cleaned throttle bodies, changed oil and all ok thanks for the suggestions
slomo is offline
post #8 of 8 (permalink) Old 09-25-2015, 12:19 PM
Glad you found that. that could have turned into a much bigger problem.
